Tahoe won’t start
Jenmaviles
Hello everyone, looking for some help
I have a 2007 Chevy Tahoe
I can’t get the Tahoe to start
Replaced the starter
Charged the battery and verified it’s at 100%
When I go to turn it over, there’s no clicking there’s no sound, but all of the electrical inside works
Pulling my hair out, please help
what does the voltage show at the battery terminals with the key in the start position? (not run position)
also did you try jumping the starter relay to see if the starter runs?
GMT800 2005 Tahoe Z71
Navy Supporting Member
Welcome to the forum from Oregon.
Live in a salt on roads state? Corrosion down the cables insulation? There is bound to be a matching relay that can be swapped to starter relay position to see if will start/turn over? Miles on the Tahoe? Will it start when in neutral? Known for ignition switch problems and frame ground problems in salt on roads states.
Kcrowe79
