2012 burb shifter
Bronson357
OK so new to me burb i can't get the shifter to m, shifter works fine in every other position. Is there something I'm missing??
B
Bronson357
It definitely shifts in to all gears fine,you can feel the clicks as they engage, you can pull back just doesn't quite "drop" into M
Thanks
B
Bronson357
Anyone know what I may need to do? It shift fine into all gears except,m ,new shift arm? Seems the cable is correct,since all positions line up. Is there a possibility of a relay or fuse causing this? I definitely feel all detents in the shifter and really no slop.
Any ides and thanks
Any ides and thanks
If you crawl under the car, can you manually shift it to "M"? Don't forget to set the parking brake and chalk the wheels so you don't get run over.
If you can, you may have a cable problem. If you cannot, you may have an internal problem with the shifter inside the transmission.
B
Bronson357
Ok so a little more seat time, it will go to m but I have to pull down fairly hard , kinda slam it. Is this normal or is something else going on?
Thank you
B
Bronson357
Nope probably have 1hr of seat time, all gears shift proper, just m is hard to get. Where is the adjustment? Thanks much
Woned2004
