I have a 2010 Suburban 5.3 6L80 that I think the torque converter is beginning to fail. I rebuilt the trans 50k miles ago but used a generic rebuilt stock style converter. I am starting to get symptoms of the converter going south and want to replace it before it trashes anything. So it seems like at a minimum it needs to have the billet cover and there are some other options as well to make it more heavy duty. I mostly just daily drive it and sometimes pull a small utility trailer but don't want to worry about it failing anytime soon. After reading thru various threads I came up with some different recommendations.
This one seems to be the most popular.
This one is a FHD. Not sure what the difference is.
This one has the billet cover and billet piston which Sonnax says would be the "better" extra heavy duty
www.sonnax.com
Then there is this one that seems to be a new comer but is all new parts and a multi disc
Then after figuring out which torque converter to buy it seems I should also look into having a transmission tune as well to change lock up and shifting characteristics to make everything last longer. I found that Black Bear Performance has an option to do transmission only tuning.
Any other recommendations would be appreciated.
6L80, 6L90 Heavy-Duty Converter Build Basics | Sonnax
Understand the options for upgrading 6L80, 6L90 stock-size, 300mm torque converters with Sonnax heavy-duty parts for JMBX, JMDV, JMDZ and JMDV units.
