GranPrix
Is this an esky? Is that the generic mishi cooler in.. Looks like 20" ? Just drain the Trans fluid, plumb that bad boy in and refill? How's it shift, afterwards? Any notable differences?
What does that poly mount do?
I get the point of studs - I did them on pretty much everything on my last build, but, do these have an issue with headers sealing, that the studs are kind of a preventative measure?
And it's all small stuff!
17 Tahoe
It’s the Mishimoto for the Silverado/Sierra. What’s the same on ours.
Like Wes mentioned, you don’t need to drain anything just add a little bit for the extra fluid you need due to the new cooler.
No noticeable difference
The new motor mounts are because there are practically zero aftermarket options and none of them last, not even the factory ones. These new mounts will probably outlast the truck itself.
The studs just make it easier to remove the headers. I used to have a small leak, but that was mainly because of the crappy gasket I had. Always go OEM.
MrTris
Attempted to install my JL AOS, today.
I have questions :
Low and High side are marked blue and red, respectively. I understand in the AOS the side with the steel wool insert is supposed to be the inlet, right? (blue) And the red side is the one that goes into the manifold, just behind the TB. My L86 doesn't seem to match their install video, so, there's that.
Hoses are a bit long and as a result, there's a kink in the TB inlet hose, not sure how to fix that. I don't think that's possible, given how it's sent.
Am I doing this right? Main reason I ask is that, although I've never had the hood open on a cold start, I did see what initially looked like spray coming from the driver's side valve cover, just below the AOS, and was a concerning amount smoke. Maybe it was just heating up, or maybe there was a problem. Somebody put my mind at ease.
Just in case, I set it back to stock so I can run around and not worry about it and I'll wait for one of you to give me a confidence boost and I'll try, again, tomorrow morning, lol.
MrTris
JLT 3.0 catch can. JLT catch cans are so nice i even installed same one in wife's 2020 Altima AWD with small madificationView attachment 304828
This is what I was looking for! Guess I'll have to order the extended version? Or is it even needed?
This picture confirms how I installed mine - did this ultimately work out? Anything you'd change?
the 18th letter
Northern New Jersey
What are you guys using to even out the bed when all seats are folded down to make a flat surface. Was looking for some type of roll out bedliner without success.
Sparksalot
Bastrop County, Texas
I took them out and made a base plate.
since getting the injectors replaced in the wifes 2016 she has reported it still having random hesitation primarily when accelerating from a stop or near stop, like slowing down and then accelerating again. no cel or anything but I did find a stored code for a knock sensor p0324-00, so ordered 2 new knock sensors and I already have new 02 sensors sitting here for it, so when those arrive I will do the 02's and knock sensors and see if anything changes
NYBRD
Spent too much time looking for tires and got a nice headache. Any reccomendations guys ? 285/45/22 on now , Im in long island NY so winter weather is always hit or miss. Past 2 full sets were Bridgestone alenza
PG01
Up here to the right
I just pulled it out put a Lloyd carpeted mat back there and called it good. Hated the slope, wife hated it more. We (her) rarely put the seats down in third row but if we fo theres a good 4-5” ‘step’ but better than havin ***** roll out on her. i open the glass first to make sure nothing is gonna fall out anyway, buts shes a shorty so doesn’t really work for her
NYBRD
Installed some b8 5100 bilstein on the front to match the rear. Had a hot mess on my hands yesterday after trying to install my front 6 piston ppv brembos couldn't make it work with my wheels( need like a .75 spacer and extended wheel studs FML so had to re install my stock caliper womp womp lol
tom3
Made a 450 mile drive in the 2019 today, I74 to I77 toll, two of us and good sized luggage load. Kept telling myself to drive conservative but still saw a lot of 80+mph. With the AFM active I got 22.3 mpg by the readout, I'll do the math tomorrow but it's usually real close. Good machine.
Got a noisy tire and can feel it, OE Goodyears with 34k miles. Looking for quality replacements now.
wwiizz
