alpha_omega
Michigan
Yup! That's the part number I have installed.
I know there are other numbers that will drop in (@iamdub ?)
Same p/n I used. The cable post is in a different location (top vs rear mount). But if you’re replacing cables anyways. Otherwise you will just route the old one a little differently by putting a kick in it.
j91z28d1
just for info. some part numbers of that 220amp can to both. the top mount is an adapter that can be unbolted
alpha_omega
Michigan
Thank you! I didn’t even take a look to see if mine was closed or able to be adjusted.
I might have to steal those two photos when I finish up the “Big 3 / Big 4 Swap” thread I’m doing.
Charlie21ny
