Same p/n I used. The cable post is in a different location (top vs rear mount). But if you’re replacing cables anyways. Otherwise you will just route the old one a little differently by putting a kick in it.Yup! That's the part number I have installed.
I know there are other numbers that will drop in (@iamdub ?)
Thank you! I didn’t even take a look to see if mine was closed or able to be adjusted.just for info. some part numbers of that 220amp can to both. the top mount is an adapter that can be unbolted
