- Joined
- Sep 19, 2018
- Posts
- 4,858
- Reaction score
- 13,713
I've never trusted suction mounts for extended GPS mounting; but some of y'all probably have actual experience with them, so tell about them, please.
joe
joe
I typically use a garmin gps for road trips, the oem suction cup has always worked wellI've never trusted suction mounts for extended GPS mounting; but some of y'all probably have actual experience with them, so tell about them, please.
joe
long time ago I used to use a bean bag mount, those are still around
if you really need something sturdy mirror mounts exist as well
Check this out...I use a crappy suction cup mount when I want GPS, but rest the bottom on the dash. Keeps it supported, steady, and out of the line of sight.I've never trusted suction mounts for extended GPS mounting; but some of y'all probably have actual experience with them, so tell about them, please.
joe
A suction cup is a temporary solution, and it WILL detach at some point. For a permanent solution, I used a RAM mount with a RAM ball to Garmin ball adapter, attached to the A-pillar. Pics at
Road trip mods
I think this is the best sub-forum for this thread; mods please feel free to relocate it if not. I'm starting with a 2016 PPV 4wd. Leaving the mechanicals stock. Want to add a few functional electronic things to make road trips nicer. I permanently-mounted and hardwired my radar detector. I...www.tahoeyukonforum.com
You don't have to drill a hole for the cable; you can tuck it behind the A-pillar. I just used the existing hole because it was there.
@Marky Dissod For me, there isn't always cellular coverage where I drive, so I can't rely solely on online nav. Also my Garmin has an alternative map that I use for logging and mining roads.
Yeah it does take some tinkeringI've given this some thought, and haven't ruled it out yet. I just hate fumbling around and smearing up my windshield.
joe
My RAM arm is a 3". It's totally stable. The 4-screw mount wouldn't work for me in that location due to the curvature of the A-pillar mounting surface. The 2-screw diamond keeps the screws inline on the same plane, and once tightened down there is no wobbling.
Yes, RAM's site is rather useless. You're better off using a retailer's site, like a GPS shop. My RAM parts are the aluminum versions, not the plastic versions.
If you're mounting to the A-pillar, in my 2016 the driver's side has a retention clip about halfway up that seems to function to pivot the A-pillar moulding towards the windshield when the airbag deploys, instead of slamming it into your face. I had to disconnect the clip to remove the moulding for drilling (didn't want to accidentally puncture the airbag), then reconnect it for the final reassembly.
Well, that's an interesting idea. Thanks.You can plenty of mounts for “items” which are attached above with the mirror mount on Amazon
Amazon.com: for Garmin GPS Mount,Compatible with Garmin Nuvi, RV, Dezl, Drive, Drivesmart, Driveassist & More,Equipped with 17mm Spherical Aluminum Rearview Mirror GPS Holder : Electronics
Buy for Garmin GPS Mount,Compatible with Garmin Nuvi, RV, Dezl, Drive, Drivesmart, Driveassist & More,Equipped with 17mm Spherical Aluminum Rearview Mirror GPS Holder: Vehicle Mounts - Amazon.com ✓ FREE DELIVERY possible on eligible purchasesa.co
I use the ones from Pro-Clip https://www.proclipusa.com/collections/dashboard-mounts-gmc-yukon-2025
Replace the suction cup with a rare earth magnet. Put a appropriate size piece of thin metal on the windshield, using good double sided tape. Easy Peasy.
Padraig
