your scanner is fine, a tech 2 while good for 300$ isn't really supported anymore. you probably have something better in your hands. unless you have like mine the odd ball hybrid one, the aftermarket scanners don't really support it. but I'm sure you're fine.
odd your trims go negative from a leak. if I remember right, when I forget to plug in the fresh air side of the pvc to the valve cover. my trims go rich, needing more fuel based off the o2 sensors saying it's lean because of the extra unmeters air getting after the maf.
anyways keep us updates on what you find
