Box or Cone Filters?
Wambliokiye
Reno, NV
Any thoughts on what air intake to use? I have herd air box, cone, duel filters and then I hear stock is the best. I know what I want but is it best for the truck. The 6.2L is what I am packin! Lol. I just wanted to do a straight tube with a big cone filter! I have always had the 454 suburbans and it was just the filter. So any info appreciated.
kbuskill
NE. FL.
Dyno tests seem to show the rubber accordion style hose between the air box and TB to be the biggest problem as it causes turbulence.
Mine is only a 5.3L but I am running a K&N drop in filter and the Airaid MIT which smooths out the flow.
I also opened up the fender opening behind the air box. It may not be needed but it certainly can't hurt.
Here is a before shot of the air box.
And an after.
And the inner fender, showing where to cut.
Some people prefer a dry filter over the K&N which requires oil. Either one is good as long as you don't over oil the K&N as it can cause problems with your MAF sensor.
Factory air box is best IMO because it is already a "cold air intake" because it pulls air from the wheel well rather than the hot air you get with a open element/cone style filter under the hood.
drakon543
all aftermarket intakes are basically the same wam as long as its a good brand. the gain differences in the end between brands doesn't matter much as they differ in such small amounts. you can get nice bonuses from upgrading the stock setup like bush and drok but most like the aftermarket for the extra wot growl. if you want the extra growl check out some images of installed intakes and pick one you think looks best to you.
The cone shaped filter without a way to protect it from ingesting hot engine air, or without a source of fresh outside air, will not be as effective as the enclosed system. So if you had an air scoop and hose delivering air close to the open filter it would be fine and not so susceptible to heat save for idle or low speeds. The stock airbox is plenty big for even a 500 horse motor. I put the K&N back in the box and am running the high capacity OE paper filter.
Wambliokiye
Wambliokiye
Reno, NV
Ok! I hear ya. I was wanting to do something like this. It has a heat sheild, so what if I ran this and also cut like kbuskill did to the fender so it also gets outside air? Or us this just for show?
drakon543
dont waste your time with ebay intakes. they dont fit right they break super easily and may or may not even work on your vehicle as intended. you would really just be buying a noise maker for most vehicles. save your time and money and buy a name brand intake.
That style is fine, just be sure of the quality like James says. Making the hole larger as Ken did to his works too, just watch those puddles or standing water!
Looks like a decent heat shield compared to most eBay intakes. But, I doubt it seals the filter from engine bay heat anywhere near as good as the OEM filter box. I'd still classify that intake to be more for show than effective air filtration.
My vote is stock filter box with Airaid MIT and a quality filter element. A direct OEM replacement filter flows plenty and filters sufficiently. I have an AEM DryFlow and it surely doesn't choke the intake and I was impressed with how clean the tubing was downstream of the filter.
nadthomas
Understand that most intakes provide very little in actual gains, and are way over priced for what they are. There biggest improvement is sound, although with that said having a nice sound can be very satisfying. Personally I like K&N filters and intakes. I run at least their filters in a stock air box on all of my cars. I had their cold air intake on my GTO and it had the best fit and finish of any CAI I have used. Others are perfectly acceptable, but if you going to spend entire too much for a tube and filter I like something that has an OEM fit and look to it.
randeez
south florida
started with air raid tube/stock high flow... bought the rest of the air raid kit - box and massive cone filter
Juangzo6
And an after.
Did you still pass smog I’m in cali Yk how it is, I had a k&n 077 high glow series sucked in hot air just orderd the aird nd gonna cut out the stock box if smog pass is possible
kbuskill
NE. FL.
I couldn't tell you, as I live in the Free State of Florida, we haven't had emissions testing here in 25+ years.
I seriously doubt cutting the fender opening would affect the emissions testing. The Airaid MIT shouldn't affect emissions testing either but may not pass a visual inspection if they look that far. Or it may be CARB compliant, I'm really not sure.
@Doubeleive could probably elaborate more since he is imprisoned with you out there.
anything not stock needs a carb sticker, a k&n filter inside a stock airbox would not be checked, they do not open anything, visual inspection only
Charlie207
LFOD, New Hampshire
Stock is better than 95%, and free.
adventurenali92
Big Bear Lake, ca
I had a cone style filter on a spectre intake for a number of years on my 2006 Denali so far have not had any problems passing smog with here in Southern California. I recently decided to put a K&N dip in filter to my factory air box that’s been sitting in the garage since the swap. But mounted to the spectre piping. Still looks good but I hated having to oil the cone filter. Cuz I live in the mountains at 7,000 feet elevation and it’s just always dusty up here and I got tired of the filter always being dusty under the hood. Factory air box looks good I think connected tot he spectre piping and I’m running the K&N filter dry in the air box. So far no problems.
adventurenali92
Big Bear Lake, ca
Good point about fit and finish! Makes everything easier when it Doesn’t present any problems for disassembly for maintenance and such when it all goes tougher nicely and easily. My spectre intake pipe mates up perfectly to the OEM air box with no modification necessary and all fits together nicely as well.
Candielaine
