This “new” 2024 GMC Yukon XL Denali is a little over a year old. It has just over 7,000 miles now. It is part of the GMC Recall for possible engine rod bearing failures. They are now recommending changing the OEM recommended oil from a 20 grade to a 40 grade, specifically 0W-40. If the original engine “passes” the test then the engine does not need to be replaced, rather the owner is to use 0W-40 oil instead. If the engine has to be replaced then the original 0W-20 oil is to be used in the “new” replacement engine.
I did not know about the recall until I reached around the 4,000 mile mark on the truck. I ran the OEM oil for 2,000 miles then got a UOA (Used Oil Analysis) (drawn from the oil stick tube). I changed the oil filter at that time to a Wix oil filter. The OEM oil was run another 2,000 miles, total 4,000 on the truck and the oil. This was the second UOA.
I changed the oil for the first time at the 4,000 mile mark to Renewable Lubricants 0W-20 oil and the filter was changed to a Motorcraft oil filter left over from my Lincoln Navigator days. I opened up the Wix filter and felt the debris was lower than normal for the milage. I was happy with this engine and felt it would last well. The engine used no oil.
I ran another 2,000 miles and got a UOA from the oil dip stick tube again. I got another UOA when I changed this 0W-20 RLI oil at the 3,000 mile mark, 7,000 total miles on the truck.
The oil now is bio-based RLI 0W-30. I got a UOA after just 100 miles, 7,100 miles on the truck.The object was to calculate the residual oil in the engine after an oil change. In any case, no indication from UOA that my engine is hurting.
ali
