Doing a transmission fluid change on my 2005 tahoe.
Kungfubenny
I bought my tahoe two years ago with 137k on the odometer. My tahoe now has 176k and i am planning to do a transmission fluid & filter change after i change my oil and filter on the engine. I will also be doing a complete brake job adding new calipers/rotors and pads.
I have already purchased all the material needed for the task but i have one question regarding the transmission fluid job.
I purchased a new transmission filter, gasket and seal as well as 1 gallon of ac delco dexron vi but after watching a few videos i found out i may need to replace 5-6 quarts of transmission fluid.
Being that it is difficult for me to locate two individual quarts of ac delco brand dexron vi, would i be able to add 1 to 2 quarts of valvoline dexron vi to compensate for the 1 gallon of ac delco brand that i already have?
Or will mixing the two brands result in disaster ie: cause issues with my transmission.
NickTransmissions
Sin City
The transmission bench
You shouldn't have a problem as long as both are rated/certified for Dex/Merc or Dex6...You can mix conventional and synthetic as well though most won't.
Kungfubenny
Kungfubenny
You are also mixing it with the fluid that won’t drain in the torque converter
True! I also considered that as well but wanted a second opinion due to mix recommendations online. With that being said im glad i came to the forums.
Job was completed an hour in a half ago starting at 10am this morning. Went very smoothly with the help of My Father in law; shifts better than ever in the time i’ve owned the vehicle. The previous gasket was still in great condition as well as the filter, I can tell the previous owner did maintenance on it before it was mine. We also added a 40k Tru Cooler and it is keeping the trans temp well between 130-140 so far, which is awesome!
All things considered this truck still has alot of life left in it. The new brake kit from Power-stop is impressive so far and looks great. Going to be driving from LA county to Sacramento tomorrow so i will definitely get a legitimate feel of the results while on the trip.
Kungfubenny
Kungfubenny
True! I also considered that as well but wanted a second opinion due to mix recommendations online. With that being said i glad i came to the forums.
Job was completed an hour in a half ago starting at 10am this morning. Went very smoothly with the help of My Father in law; shifts better than ever in the time i’ve owned the vehicle. The previous gasket was still in great condition as well as the filter, I can tell the previous own did maintenance on it before it was mine. We also added 40k Tru Cooler and it is keeping the temp well between 130-140 so far, which is awesome!
All things considered this truck still has alot of life left in it. The new brake kit for Power-stop is impressive so far and looks great. Going to be driving from LA county to Sacramento tomorrow so i will definitely get a legitimate feel of it all while on the trip.
