Adding cats to LT headers - need some expert input.
Charlie207
LFOD, New Hampshire
I'm close to buying the Speed Engineering LT headers & Y-pipe kit, and want to add catalytic converts to pass emissions, and not stink.
Headers & Y-pipe kit: https://speed-engineering.com/colle...erado-sierra-1-3-4-longtube-headers-2007-2013
There's not a ton of info (as far as I've seen in the last 24 hours of sort-of searching) on the best way to splice in cats., so I figured I'd ask here for how you guys have done it.
I've read that there is a minimum distance from the end of the collector to the face of the cat. substrate, to allow for effective exhaust scavenging. That doesn't seem to leave a ton of room on the driver's side for adding a cat. I see there is a drop-in set of headers w/cats from Stainless Works, but that is too rich for my blood. Their design does offer a basic template to go off of, though.
So far, these are the shortest OBD2-compliant cats. w/O2 bung that I've seen: https://performance-curve.com/3-catalytic-converter-o2-high-flow-for-late-models-federal-emissions/
Thoughts?
If I were adding long tube headers to mine, I would also purchase a catted Y-pipe from that manufacturer. They've already figured all that stuff out and use performance catalysts.
I see why now, that's a huge difference in price compared to Kooks, American Racing, etc.
Charlie207
Charlie207
LFOD, New Hampshire
Yeah, I'm not trying to spend $2000+ dollars worth of exhaust on a car that's worth maybe 8-10k.
I do have a welder friend with a shop to lift the car up, so that's a plus, vs. my normal rolling around on a gravel driveway.
It may only have a market value of $8-10K but how much would it cost to replace it?
I'm slowly getting mine ready for more power, going to spend a pretty penny on a 3.5" Y-Pipe and exhaust system, about $3.5k.
How long will those headers last compared with Kooks for example? If they'll last longer than you plan to keep your truck then it makes sense.
992dr
Eastern N.C.
It's been a while, but I have cut down cats for this exact reason. It's easier to adapt them with a little ingenuity.
They started out as 2.5"in/out Magnaflow spun metallic converters, and I cut them down to 3" in/out. It shortens them quite a bit for tight spaces.
Personally, I'd prefer a quality header and a fabricated y-pipe :)
Foggy
KS
I looked at what Kooks stuff is now $$$$$$$
I really like my Kooks headers and catted Y pipe..
But WOW ! I bought mine before the plandemic and *****omics
They have doubled in price !!
I did the SS headers & Y.. Then had them thermal coated for
longevity . I'm very happy. I've heard horror stories about the
cheaper headers with spark plug access , quality, leaks, etc
Charlie207
Charlie207
LFOD, New Hampshire
I'm probably going to roll the dice with Speed Engineering headers and Y-pipe. There seems to be many more positive experiences than negative.
buckwild27
EMT/First Responder Firefighter
Ohio
I live in the land of rust and spent the money on 1 truck for the stainless works system front to back. It holds up.
Charlie207
Charlie207
LFOD, New Hampshire
If my rig were newer or had less rust potential I'd probably save up, but I estimate 4 years or so before it becomes a full-time job fighting the inevitable rust devils.
buckwild27
Ohio
Yeah my truck got crashed into in a parked garage so it's done for. But a side note the body of a short box 1967-72 chevy C-10 fits on the tahoe chassis so the exhaust system will live on.
buckwild27
Ohio
Trey Hardy
I’ve had 4 sets or more on my trucks and haven’t had an issue with them at all.
Also just about every one of my friends has ran them also (atleast 6 off the top of my head) with no issues and my tuner put me onto them and can get them discounted (think my last set was like 275-300$ something.
For the money I’d buy another dozen before I spend 1000$ or more for a different set
Trey Hardy
Like said below use quality MLS header gaskets and I put arp stainless bolts in BUT if I had it over again I would’ve gotten the studs for easier installation
Dh1280
