A brake job rabbit hole
C
cofferson
It occurred to me...how did you figure out the RAM modules were compatible?
So it isn't really compatible but it has many of the same circuit board parts since it is the same manufacturer. I found out the manufacturer of the unit and AI gave me some vehicles that use that supplier. There are companies that fix a variety of these boards and they have pictures at the checkout stage. So once I knew some rams, chevys, and Volkswagens used this supplier, I was able to just pop hoods at the junkyard until I found one that had the white solenoid I needed.
OBSandaNNBS
Known Thread-jacker
Brilliant. Thank you, learned a new fixit avenue today :Handshake:
Noggles
Not sure if I missed it during your bleeding process but a power bleeder is SUPER helpful in pushing the air and fluid through the ABS block. I used my Motive Power Bleeder to help my friend bleed the brakes in my old 05 Tahoe after he replaced the ABS pump in it and it only took 2-3 tries to get as much air out as we could see. Not super expensive but VERY useful.
CWool
