2010 Suburban 5.3 P0521 Oil Sensor
DT360
Yet still the cluster shows I have normal pressure. I have swapped out three (plus the filter) now (acdelco/gm) and I still have the cell. Any Ideas from this point on?
Charlie207
LFOD, New Hampshire
Are you saying you switched out the oil pressure sensor, and still get the CEL?
How is the wiring... any frays, cuts, pinches?
D
DT360
Yes, i swapped it out three times (thinking i had bad sensors). Now I know I have three good sensors and it is my chevy that is the issue.
I checked the wiring (from what I can tell at the port and what my eyes and hand can see/feel) checks out. No breaks, fraying of any sort.
Super Moderator
Elev 5,280
Has the filter below the oil pressure sensor been verified as clean?
What does the gauge read if you unplug the sensor?
D
DT360
Yes I removed it complete and undamaged with a 5/16 lag screw. No I have no tried that. I will unplug it this evening.
j91z28d1
the dash runs off the same sensor.
things aren't really adding up. first. do you have a scanner? if so what's it say for oil. pressure. if not, what does your gauge read?
D
DT360
scanner and gauge reads 20psi.
When unplugged, reads 0. Sensors are good (who needs a new used sensor lol).
It's been reading 20psi for a decade and now it wants to fault. I'm taking a stab in the dark here but I'm going to replace the barbell on the rear motor when i drop the transmission this summer/next month. If i'm feeling it, i'll replace the cam shaft thrust plate up front too (I reused my old one b/c I was running out of time - dumb i know).
j91z28d1
is it like suck on 20psi and doesn't move? kinda makes it sound like it's not low oil pressure as much as it's just not doing what expected.
Engine Oil Pressure
(EOP) Sensor
Performance
P0521 Determines if the Engine
Oil Pressure (EOP)
Sensor is stuck or biased
in range
To fail a currently
passing test:
Diagnostic enabled /
disabled
Performed every
100 msec
50 failures out of 63
samples
Performed every
Enabled
< -50.0 kPa OR >
50.0 kPa
Oil Pressure Sensor In
Use
The filtered,weighted
difference between
measured EOP and
predicted EOP (a function
of engine speed and
engine oil temp.):
Present
> -47.0 kPa AND <
47.0 kPa
Engine Oil Pressure
(EOP) Sensor
Circuit Low Voltage
P0522 Determines if the Engine
Oil Pressure (EOP)
Sensor circuit voltage is
too low
(Engine Oil Pressure
Sensor Circuit Voltage) / 5
Volts
Filtered engine oil
pressure test weighting
(function of engine speed,
engine oil temperature,
predicted oil pressure, and
engine load stability).
Details on Supporting
Tables Tab (P0521
Section)
>= 0.30 weighting
To pass a currently
failing test:
The filtered, weighted
difference between
measured EOP and
of engine speed and
engine oil temp.):
losloho02
