Yes I removed it complete and undamaged with a 5/16 lag screw. No I have no tried that. I will unplug it this evening.Has the filter below the oil pressure sensor been verified as clean?
What does the gauge read if you unplug the sensor?
I"ll give this a go.You may want to walk through the diag procedure:
P0521 — 2010 Chevrolet Suburban 2WD V8-5.3L Service Manual | Operation CHARM
Detailed repair manual for the 2010 Chevrolet Suburban 2WD V8-5.3L.charm.li
scanner and gauge reads 20psi.
When unplugged, reads 0. Sensors are good (who needs a new used sensor lol).
It's been reading 20psi for a decade and now it wants to fault. I'm taking a stab in the dark here but I'm going to replace the barbell on the rear motor when i drop the transmission this summer/next month. If i'm feeling it, i'll replace the cam shaft thrust plate up front too (I reused my old one b/c I was running out of time - dumb i know).
