Torque specs for rear suspension? 13 Tahoe LTZ
Atrevino0497
I’m going to be doing an extensive tuneup to my Tahoe as she’s nearing 160k. She doesn’t ride as nice as she used to.
Plugs + wires, engine filter, front and rear diff fluid, new transmission pan with drain plug, new trans filter and fluid, transfer case fluid, brakes and rotors then suspension components and alignment
I need help with torque specs for rear suspension, I’m deleting the auto ride in the front with resistors but keeping the rear factory
Front:
Kyb struts
upper control arms (replaced lowers last yr)
Sway bar links
Inner and outer tie rods
rear:
upper and lower control arms
Stabilizer bar links + bar bushings
Rear Lateral link
Shocks (factory air ride)
Thankyou
REAR SHOCKS 85FT LBS
REAR UPPER CONTROL ARM 118FT LBS
REAR LOWER CONTROL ARM 74FT LBS +55deg
rear sway bar 48ft lbs + 40deg
rear panhard bar, just make it as tight as you can reasonably get it otherwise it may make popping noise
def 80+ft lbs
Atrevino0497
Atrevino0497
def 80+ft lbs
Thankyou very much ! I really appreciate this, I cannot wait to get started and feel the improvement
GranPrix
def 80+ft lbs
Wes, do you think these would apply to the next gen 15-20? I’ve been scouring the Internet for over an hour and nobody, and I mean, nobody has any information on the track bar, upper and lower rears for the K2s
PG01
Up here to the right
Frames are basically the same so I would say they gotta in the same ballpark maybe even in the same batters box….
j_jerry79
