2008 escalade third stoplight
Tazio
I just purchased a 2008 Escalade and I don't know if the third stoplight is supposed to have a directional signal function or just the center third as a stoplight? While I was hooking up a trailer brake controller, I found that the high mounted stoplight wire output wire was always hot with the key in the on position but the center light worked normally when applying the brake. Replacing the s/l switch cured the brake controller circuit but didn't change the third s/l. If this is the normal operation, I'll just let it be. Other than that, the car is very well maintained (dealer over selling service) with only 81,000 miles on it. I intend to use it as a back up tow vehicle in case my 2007 Yukon With 177,000+ miles on decides to take a dump. I don't want the headaches that come with the newer models with cylinder deactivation!
2024 White Tahoe
You may want to post in the 2007 - 2014 section.
PPV_2018
Molon Labe
U.S.A.
No, the chmsl should only act as a third brake light only when brakes are applied, not with any directional function.
petethepug
Michael
SoCal
I’m sure that tail light set up has a tranquillizing effect on local wildlife. See stuff like this in your rear view camera?
Towmaster
