What did you do to your 21+ T1XX today?
CCPLuvr
Installed the DFM Disabler today and drove around a bit. It's nice not having to remember to hit the auto on/off button or set the tranny to L9 everytime. Hopefully this addition will help the longevity of the engine...
Big Mama
Virginia
I haven’t heard of this L9 trick. What’s it do?
CCPLuvr
JayceeP
Summer rims are back on.
Lonny
Here's the laundry list summary of (almost) everything...
Ceramic + PPF + blackout tint
CB/Emergency Comms (aerial is in front of the GPS mast)
Emergency / strobe lighting system
Onyx painted mudguards / all wheel wells
Lonny
And the rest (couldn't insert it all above)
T-Mobile Hotspot (located along side of rear seat and hardwired under the floor panels to outboard battery under front passenger seat)
Lonny
Thinkware iVolt Xtra outboard battery system + Thinkware U3000 Surveillance System (24/7 front and rear cameras + radar + 24/7 Internet)
Emergency strobe lighting control switch
And various other protective measures I can't elaborate on...
JayceeP
American Honey.
Annual ceramic maintenance: Iron removal, clay, ceramic topper. Ready for Spring and Summer.
derfman00
Stopped my washer fluid from leaking out in the rear. Common problem it seems. If it leaks again I'll add a hose clamp. I couldn't get enough leverage on a zip tie to make it snug enough to keep from being pulled off. This picture is from the rear passenger side pointing toward the center of the vehicle. Drop the spare to get easier access.
Biggest fear is a hose clamp here might move the point of failure to inside the vehicle beyond the passenger rear side panel as that is the other place people have had leaks... stupid engineering design
jd08
Jackson, WI
Install Airaid jr kit today. I just used MIT tube for now. Will put the dry filter in later. Cleans up the engine bay.
Took it into town to pick up some food and it makes the 6.2L growl. I was surprised. I will see what the wife thinks tomorrow after she drives it.
rlhmarines
Senior Member
Marine Corps Supporting Member
SHE looks good !
Thanks, I know it’s going to be a bear to keep her looking this good going forward for the wifey.
She wanted something a little smaller like the Traverse but I won out on the new “Hoe” size wise but she prefers black on black color and interior so it’s win win in my opinion.
olyelr
Elk Rapids, MI
The traverse isnt too horribly small, but theres nothing like having a fullsize rig ! The cargo room in these newer short ones is quite underwhelming for sure, but still, the extra arm room and everywhere else…so worth it.
glazar
