2025 Yukon AT4 Ultimate wind leak noise
AMM1986
I have recently got my 2025 Yukon AT4 Ultimate and while driving around 40 mph I hear sound of wind leakage from the window on driver’s side and gets really worse when speeding up. Went to agency and they said it had something to do with the alignment of wind deflector which they fixed and now it’s gets even worse but starting from 55 mph, like really annoying. Any fixes to that or did anyone face this before?
Thanks.
2024 White Tahoe
Thanks.
What is agency?
Do you have an aftermarket wind deflector on your vehicle?
KMeloney
What wind deflector? Are these aftermarket add-ons?
Silverado4x4
OK, so you say they adjusted the wind deflector what wind deflector are you talking about? These vehicles don't have wind deflectors. We need to understand what your talking about so we can help you.
rlhmarines
Senior Member
Marine Corps Supporting Member
The only wind deflector that comes to mind is the panoramic sunroof’s wind deflector that deploys when open, otherwise it could be the door molding is not fully seated correctly causing the wind noise but that’s just a guess.
A
AMM1986
Actually they did mention something about the door and its alignment too
BacDoc
Vero Beach Florida
Get some masking tape and tape the door and mirror gaps. Take it for a ride and see.
This is the scientific method! Eliminate the variables.
Might be good to measure the gaps between door and body and compare both sides to see if there are differences.
It might be difficult to tape the seams yourself as you can’t use the driver’s door after taping it.
jjobev
Did fixing the alignment on the doors solve your problem?
Semper1833
I would like to know as well if a fix was found, 2026 Tahoe High country and I did tale test and fixed the noise, seems to be where window goes into upper door frame.
Miami-Dade
Moderator Supporting Member
Sorry to report the OP has not been here since May 4 .
Tupapi
