2010 Yukon radio wiring
JohnCaper
I'm replacing the stock radio (Delphi pn 25966515) with an aftermarket radio. I purchased the adaptor so that I don't have to cut the factory wiring but am struggling to find details on which wire is the accessory power, and the steering wheel controls. I've found details on the pins but the source doesn't list these. Any help is greatly appreciated.
Tonyv__
Bucks county PA
Assuming you bought the cheap harness (no offense, that’s what I use). You need to tap your own accessory into the fuse box.
As far as steering wheel controls, hopefully someone else will chime in for you.
JohnCaper
JohnCaper
Isn't one of the wires on the original plugs accessory power?
Tonyv__
Bucks county PA
No
i couldn’t even explain to you how the factory radio gets its turn on signal but I’ve installed enough radios in GM trucks to know the accessory wire just isn’t there
Tonyv__
Bucks county PA
you don’t need to splice into the fuse box with anything permanent. Get one of these fuse taps and go after one of the fuses that turn on and off with the key like hvac control or something. Then run it to the back of the radio
JohnCaper
JohnCaper
Thanks! From what I'm reading the Yukon needs a separate module/interface for the SWC. Not sure if this is correct or not but the SWC isn't that big of a deal
Tonyv__
Bucks county PA
I’ve never tried. I find myself rarely using my steering wheel control even when it does work
Another note, you may not realized this until you get the radio functional, but you will lose all your chimes like the turn signal clicking sound, seat belt chime, onstar if equipped, dummy lights chimes. A lot of stuff is integrated into the factory radio, that’s why they sell an expensive harness and a dirt cheap one.
Call Crutchfield and explain what you have for a new head unit, and they will advise you on the correct interface unit to have, in order for your SWC's to work properly.
Eickybobby5050
