Looking into a used 2014 tahoe
Kingshawaiinrolls
Hey, I’m brand new to forums. I am looking at a used 2014 Tahoe and I had heard that there are people in forums that can get something similar to a carfax report on here for free. I am mainly looking to see if the odometer has been rolled back but all info would also be much appreciated. Here is the vin #: 1GNSKBE01ER225769. Also any other info on things I should look for when going in for the test drive, such as rust in particular places, would be awesome. TIA!
Welcome to the Forum from NH.
Pics of the truck, please.
I cannot personally assist you with your request, but other members of this Forum much more knowledgeable than me in this area will chime in.
Pay for the CarFAX. It says it has been in one accident with no damage. If it was some time ago, I would not cross it off my list.
It looks to be in great shape and is well optioned. Have you seen it yet?
K
Kingshawaiinrolls
K
Kingshawaiinrolls
I have not gone and looked at it yet. Someone I know is very familiar with these motors and will be coming to take a look at it with me sometime this week. If it looks good to him and I, I will do a carfax and go from there. I was really hoping to not pay 50 dollars for that but if it comes down to it I will. Thank you
Don't loaf around, the good cars sell fast.
This is a 12 year old car, you ought to budget in a few grand in repairs and maintenance. It's not likely that any of the fluids have been changed yet. Since it's a northern car, check for rust in the undercarriage. Surface rust is normal and rot is something else. I see pickups all the time with good rust free bodies but their frames are rotted out.
Here's a breakdown of the RPO codes, the options the truck was configured with:
1LT PACKAGE LT OPTION 1
1SZ DISCOUNT OPTION PACKAGE
6PB COMPONENT FRT LH COMPUTER SEL SUSP (6PB)
7PB COMPONENT FRT RH COMPUTER SEL SUSP (7PB)
833 TRIM COMBINATION LEATHER, DK TITANIUM/LT TITANIUM (3) (08)
83I INTERIOR TRIM DARK TITANIUM/LT TITANIUM (I) (08)
89U PRIMARY COLOR EXTERIOR, CRYSTAL CLARET TINTCOAT (505Q)
A31 WINDOW POWER OPERATED, ALL DOORS
AG1 ADJUSTER FRT ST POWER, MULTI-DIRECTIONAL, DRIVER
AG2 ADJUSTER PASS ST POWER, MULTI-DIRECTIONAL
AJ1 WINDOW TINTED DEEP, ALL EXCEPT W/S AND DRS
AJ7 RESTRAINT SYSTEM SEAT, INFLATABLE, DRIVER & PASS, FRT & SEAT SIDE
AL0 SENSOR INDICATOR INFLATABLE RESTRAINT, FRT PASS/CHILD PRESENCE DETECTOR
AL4 SEAT RR BKT
AN3 SEAT FRT, INDIVIDUAL (NON BKT)
AP3 LOCK CONTROL, ENTRY REMOTE, KEYLESS ENTRY, START
ARL PLANT CODE ARLINGTON, TX, USA
ARS ADJUSTER RR REAR SEAT, POWER, STOWABLE
AS3 SEAT REAR UTILITY
ASF RESTRAINT ROOF SIDE, LH & RH, INFLATABLE
AU3 LOCK CONTROL SIDE DR, ELEC
AXP VEHICLE TYPE MULTI-PURPOSE PASSENGER VEHICLE
B30 COVERING FLOOR CARPET
B58 COVERING FLOOR MAT, FRT & RR, CARPETED INSERT
B85 MOLDING B/S EXTERIOR, BRIGHT
BVE STEPS, RUNNINGBOARD SIDE
C25 WIPER SYSTEM RR WINDOW, INTERMITTENT
C36 HEATER AUXILIARY
C49 DEFOGGER RR WINDOW, ELECTRIC
C69 HVAC SYSTEM RR AIR CONDITIONER
C6A GVW RATING 7, 300 LBS
CF5 ROOF SUN, GLASS, SLIDING, ELEC
CJ2 HVAC SYSTEM AIR CONDITIONER FRT, AUTO TEMP CONT, AUX TEMP CONT
D07 CONSOLE FRT COMPT, FLOOR, CUSTOM
DCP PROCESSING DIRECTIONS & CONNECTIONS SERVICE PACKAGE
DD8 MIRROR I/S R/V LT SENSITIVE
DH6 MIRROR I/S FRT VAN LH & RH, SUNSHADE, ILLUM
DK8 CONSOLE ROOF INTERIOR, DELUXE
DL3 MIRROR O/S LH & RH, REMOTE CONTROL, ELECTRIC, HEATED POWER FOLDING, TURN SIG IND, LT SENSITIVE, COLOR
E52 BODY EQUIPMENT ONE PIECE LIFT GATE WITH LIFT GLASS
E61 DOOR RR LIFTGATE, POWER
EF7 COUNTRY UNITED STATES OF AMERICA (USA)
FE9 CERTIFICATION EMISSION, FEDERAL
FHS VEHICLE FUEL GASOLINE E85
G80 AXLE POSITRACTION LIMITED SLIP
GU6 AXLE REAR 3.42 RATIO
I14 ENGINEERING YEAR 2014
JD9 BRAKE VAC POWER, 17" DISC/DISC, W/VSES, 7700 LBS
JF4 PEDALS ADJUSTABLE, POWER
JL1 CONTROL INTEGRATED TRAILER BRAKE
JL4 CONTROL ACTIVE BRAKE
K34 CRUISE CONTROL AUTOMATIC, ELECTRONIC
K5L EQUIPMENT Enhanced Cooling Package
KA6 HEATER SEAT, RR
KC4 COOLING SYSTEM ENG OIL
KNP COOLING SYSTEM TRANS, HD
KW1 GENERATOR 160 AMP
LMG ENGINE FLEXIBLE FUEL, (GAS/ALC), 8 CYL, 5.3L, SFI, V8 OHV, CYL DEACTIVATION, IRON, GM
MYC TRANSMISSION AUTO 6 SPD, HMD, 6L80
NP5 STEERING WHEEL LEATHER WRAPPED
NQH TRANSFER CASE ACTIVE, TWO SPEED, SWITCH ACTIVATED, ALUM
NT7 EMISSION SYSTEM FEDERAL, TIER 2
NZ4 WHEEL SPARE 17 X 7.5, J, STEEL, DESIGN 2
PCJ CONTROL SALES ITEM NO. 103
PCK CONTROL SALES ITEM NO. 104
QSS TIRE ALL P275/55R20-111S BW TL ST AL2
R5C TIRE BRAND ALL BRIDGESTONE
R6Q CONTROL SALES ITEM NO. 16
R9N CONTROL SALES ITEM NO. 89
R9Z CONTROL SALES ITEM NO. 100
RCS WHEEL 20 X 8.5, ALUM, POLISHED FINISH(CHEV)
SAF LOCK SPARE TIRE, HOIST SHAFT
SLM SALES PROCESSING STOCK ORDERS
SLT EQUIPMENT 'LT' SALES PKG
T74 HEADLAMPS CONTROL AUTOMATIC, DELAY
T96 LAMP FOG, FRT
TL1 GRILLE SPECIAL
U42 ENTERTAINMENT PKG REAR SEAT, SINGLE DISPLAY, REM CONTROL, AUX JACK 2-WIRELESS DUAL CHANNEL HEADPHONES
U84 ANTENNA BODY SIDE WINDOW, RADIO
UBS DIGITAL AUDIO SYSTEM S-BAND AND TRAFFIC
UD7 SENSOR INDICATOR REAR PARKING ASSIST
UE1 COMMUNICATION SYSTEM VEHICLE, G.P.S. 1
UG1 OPENER GARAGE DOOR, UNIVERSAL
UJM TIRE PRESS INDICATOR MANUAL LEARN
UK3 CONTROL STEERING WHEEL, ACCESSORY
UK6 RADIO CONTROL RR SEAT & EARPHONE JACKS
UPF WIRELESS INTERFACE SHORT RANGE, VOICE REC
UQA SPEAKER SYSTEM PREMIUM PERFORMANCE ENHANCED AUDIO
USR RECEPTACLE USB
UVC CAMERA REAR VIEW
UYS RADIO AM/FM STEREO, NAV, DVD-ROM, CAF, HDD, USB RSA, RSE (GMNA VERSION)
V1K BAR LUGGAGE CARRIER, CENTER CROSS
V54 LUGGAGE CARRIER ROOF, PAINTED
V76 HOOK TOW
V8D VEHICLE STATEMENT US
VFF VIDEO FORMAT REGION 1, NTSC
VGD FASCIA FRT, CUSTOM, BODY COLOR
VGE FASCIA RR, CUSTOM, BODY COLOR
VK3 LICENSE PLATE FRONT FRT MOUNTING PKG
VR4 TRAILER HITCH WEIGHT DISTRIBUTING PLATFORM
VT7 OWNERS MANUAL ENGLISH LANGUAGE
VZE VIN MODEL YEAR 2014
X88 CONVERSION NAME PLT CHEVROLET
XL7 FREQUENCIES RATING 315 MHZ, LONG DISTANCE
YD3 AXLE (BASE EQUIP) FOR SCHEDULING GVW PLATE
YD5 SPRING FRONT BASE EQUIPMENT
YD6 SPRING RR, BASE EQUIPMENT
YE9 CONVENIENCE PKG COMFORT & DECOR LEVEL #3
Z82 TRAILER PROVISIONS SPECIAL EQUIPMENT, H.D.
ZRS TIRE SPARE P265/70R17-113S
ZW7 CHASSIS PACKAGE PREMIUM SMOOTH RIDE
ZY1 COLOR COMBINATION SOLID
She has the base suspension, no air shocks or compressor for leveling. So she'll have a basic rake for towing.
Charlie207
LFOD, New Hampshire
The good thing about it being the final year of the GMT900 is that it'll have the most kinks worked out.
The RPO list looks basically the same as my Yikon, and it has the decent stuff: cooling/towing package, final drive, LSD. It should make for a great daily-driver, or base for future upgrades.
petethepug
Michael
SoCal
She’s pretty. Black carpets are a huge plus. Looks like it was garaged 24/7. No visible wear on console buttons. DVD player & the HDD Navi with active / moving grid lines for back up cam. No autoride to mess with.
109k clicks on the clock, 2Sp xfer case 4WD. It’s the best of the best.
CKendrick
