Can this crack cause a vacuum leak?
abdullah_Zahra
My 2010 Suburban has been giving me the p0174 and p0171 intermittently with no check engine light. Upon visually inspecting the engine I found this. Could this be the cause?
No chemicals, they can mess up your O2 sensor readings. Just use duct tape or something at first. Then you can get an Air Aid Junior or another from the local salvage yard.
^^^ This. Tape it up for now but get a pre-loved one from your local Upull or a junkyard (search www.car-part.com, "air cleaner").
Charlie207
LFOD, New Hampshire
I would gently melt it back together with a soldering iron, and snip off a strip of similar material from that big tab (on the left side of your picture) to use as filler.
I did that to a hole in my intake manifold, and it's holding up great.
GMCChevy
A bit of silicone, glue gun, electrical tape, jb weld... Easy fix.
j_jerry79
