Please double check my t-case repair plans
ThinkingJack
I am repairing the t-case on my brother’s 2002 Tahoe LT, 5.3 and NP246 case. He’s had the truck since new and it’s well maintained (205k mi). He went to change the t-case fluid the other day and the fill bolt was seized in the threads, rounded, and cracked the housing. I did search this forum and read old threads on it; very helpful. I have rebuilt one GM auto transmission before, and some manual trans, so I am pretty confident in what I’m doing, BUT: I’ve never worked on this exact transmission before.
He ordered the Dorman aluminum replacement, this:
https://shorturl.at/IxlXa
He and I took the t-case out today. When we started to remove it, a decent amount of fluid came out from between the units - red ATF. I understand this to mean the trans output is leaking into that cavity as it should have been dry? Bushing inside the trans is worn and/or the drain back is clogged? So, here’s my plan and questions:
1) I am buying this Transtar t-case kit, which will give me new seals and the paper gasket to the adapter to replace all the t-case in/out seals.
https://shorturl.at/vkwo1
2) What is between the t-case halves? Paper gasket? FIPG? I didn’t break it open yet. We did the water pump and pulled the t-case and called it a day.
3) If I take that transmission mount/middle adapter out, can I access the transmission output shaft in any way to address all that fluid in there? I have looked at videos, and I do not see an externally replaceable seal.
4) I noticed a slight leak on the left at the pan edge, I am assuming a shift shaft seal weeping a bit from above. I saw the tool for that and will replace that while under there.
5) I found some $15/$20 “Case saver” plates to buffer the t-case oil pump ears. Simplified stamped steel versions of the “Merchant” saver device it appears to me. Is that necessary with the improved Aluminum housing?
Also I cut one of the transmission support bracket bolts out; the exhaust and O2 sensor bung prevented removal. I need to get a new bolt and insert it from the other direction. Plenty of room; seemed weird they did that. I was NOT messing with the exhaust to get that bolt out. ;) I will go to Tacoma Screw to try to match the bolt, if not available there, where is a fairly priced GM parts source to order one from (I don’t work on a lot of GM products - just our Mom’s Euinox, though I am contemplating buying a late GMT 800 or early GMT900 Tahoe to replace my beloved Trooper).
Appreciate any advice or checking my thinking.
justirv
If I recall the t-case halves are sealed with a RTV, I don't recall specifics. I replaced the hyvo chain and all rubber. I did add the case-saver for added comfort. If you plan to do the clutch pack, you'll need a special tool (always, right?) to determine proper shimming. J-44295 KENT MOORE SHIMMING TOOL. You could probably have that shimmed at a local shop for reasonable cost. This tool (used) is around $400+.
NickTransmissions
Sin City
The transmission bench
That kit should be correct for your T-case
All the internal components, including the chain/sprocket set, gear set, clutches, etc - cant recall if RTV only or a gasket (Think it's just RTV) - use Permatex Ultra Black if so.
There's no rear transmission seal on 700-R4s or 4L60E transmissions so nothing to service; the output shaft will have a little inboard-outboard play as well as slight bit of side play but shouldnt move in/out much or side-to-side much...
You can use the tool to yank out the seal or drop the pan, remove the 15mm selector shaft-to-rooster comb nut, slide the selector shaft out then pull the old seal out with a flat blade screw driver or small pry bar then install the new seal w/a 15mm deep socket (i think 9/16" will also work). If you drop the pan, install a new pan gasket and filter then reinstall the pan and torque all 16 bolts to 98-100 inch lbs. You will prob need to go around twice to three times to fully compress the gasket...DO NOT use a flimsy rubber gasket or a cork gasket...Only a composite gasket ($2-$5 at hard parts suppliers) or a Victor Reinz molded steel/rubber gasket.
Not sure - perhaps @rockola1971 can comment
rockola1971
Indiana (formerly IL)
Since you have to open the Tcase up, You should put a case saver plate in there. They are cheap enough and do their job well. I use Red Rtv between the cases of the Tcase and between the Tcase and the tranny adaptor. The Tcase has a double lip seal to prevent tranny fluid entering the Tcase and overfilling it and the it also prevents the Tcase from emptying into the Tranny. Make sure you lube it well when installing the input shaft so it is not damaged.
jfoj
A great shop to get reasonable prices rebuilt transfer cases from is the Gear Shop in Baltimore, MD. I got a rebuilt AWD transfer case from them for my 2005 Yukon Denali AWD and actually picked it up and dropped of the old unit. My unit was leaking like crazy and I think I have had the rebuilt unit for over 3 years in the truck now without problems. I was SHOCKED at how many transfer cases cores they had in inventory, hundreds stacked floor to ceiling. I think they said they rebuild over 1500 transfer cases a year or on average probably over 6 per day.
They have fixed pricing so you do not get the run around about what is worn or what needs to be replaced.
The Gear Shop
T
ThinkingJack
I decided this was smart and order a transaver insert. I will put that in even w/the new rear case. I appreciate the comment ( and all others in the thread, even if I did not respond directly).
T
ThinkingJack
Thank you, @NickTransmissions for looking over this.
I do appreciate that. I’m an expert in other subjects at different forums. I try to be helpful/insightful, spend a lot of time trying to help - wondering if it does. I’m not an expert here. I really appreciate the effort/extra time a real expert takes to help strangers, promote the platform, enhance the forum. Thank you (and others).
NickTransmissions
Sin City
You're welcome, man. Thanks to @rockola1971 as well - he's a SME and very knowledgeable about the t-cases whereas I hardly ever rebuild/touch them.
T
ThinkingJack
Again, thanks to all. We got it back in this weekend w/o too much drama. I did use a case saver as @rockola1971 recommended.
Only hiccup was I broke the plastic at the trans cable mount when I took the cable off to replace the shift shaft seal. A few follow ups:
1) I see a 131” and 140” cable kit are both listed, which one is correct (2002 Tahoe), or is one a revision? (Difference being an extra 9” in the lower cable). I can’t get the AC Delco one tomorrow, so those are aftermarket ones. I am not at the truck to just pull it out and measure. This is what confuses me, both are listed as correct:
2) Any tips on checking trans fluid level? My brother said he had trouble getting a clear reading, I need to check that tomorrow.
3) This is how the front driveshaft output looks, with that gap between the boot and the seal, leaving it slightly open. Looks odd to me (it’s how it was when we disassembled it). Granted it’s behind the case shield. Normal?
Thank you all again.
Gap between arrows is what I mean.
a1parrothead
