NHTSA opens preliminary probe into more than 870,000 GM vehicles
jfoj
Well you have started out much better than most owners. Get the 0W20 out and drive around town in L9 for now. You could drive in L9 on the highway if you wanted to give up some fuel economy.
The next thing I need to check and see if Trailer or Sport mode shuts down DFM??
Scarey
I think it has been shown on various threads sport/tow does not shutdown Dfm.
jfoj
My 2024 was an August 2024 build with the engine build date of July 15, 2024.
My spare fuel pump modules are the 4821 units, I do not think I checked the part number of the original yet
Jayhawkeye3
I’ve been following this because I’m in the market for a Hoe or Denali. Are the 2025 models impacted here too? Seems as if they are, which would give me serious pause and/or shift to the baby diesel.
Stbentoak
Has anything materially changed for 25 that would say that "It's over with"? I don't believe so.....
jfoj
Article from The Car Connection
Seems to indicate that at least 346 reports have been filed with NHTSA. Assume this is less than 20% of actual failures?
A comment indicated that GM has until March 28th to provide requested information. Then NHTSA needs to digest all this info and decide if they need more data or what if anything they may request GM to do in order to address failures. We shall see what happens and when, I do not expect any solid info until Sept or later.
The Car Connection Article
viven44
Dallas, TX
@viven44
You cannot easily tell if the transmission is shifting between 9th and 10th gear and vs versa. Between the TCC slip design and the very small gear ratio difference between 9th and 10th gear, you may not notice it much. The transmission progamming differences between the 5.3l and 6.2l are different, I have confirmed this. But if you are really located in Dallas the road a fairly flat and the 5.3l should be able to hold 10th for a bit before it may downshift into 9th gear. I can monitor and log what gear my transmission is in and I was watching it the other day in a rural setting where I would hit 10th gear at 45-50 MPH, usually below 45 MPH it would usually not shift out of 9h gear.
There is nothing wrong with the my truck as configured, this is the way GM has set them up. At 55 MPH my engine is turning 1200 RPM, at 65 MPH my engine is turning 1400 RPM. The 6.2l is behaving like a Diesel the way it is programmed. Now you might understand why so many of the 6.2l are suffering from bearing failures. The 6.2l has more lower end torque than the 5.3l, but the 5.3l will shift into 10th gear probably around 50 MPH, it just may shift out of 10th or even 9th gear earlier than the 6.2l.
Finally got to this after 3 months. Lo and behold my scanner did the software update for GM in 2 mins, ha ha
I was watching it get up to 8th gear as low as 38mph in city driving, but dropped down to 4 when the throttle was pressed any.
See below graph on how it shifts on the highway.
On the highway, merging to about 60mph was in 6th gear and I drove it really gently at ~55-60mph to see if it would get up to 10th gear, it actually did to my surprise. it slowly got up to 10th gear and stayed there but the slightest bump in the throttle got it down to 8/9.
I didn't get the chance to drive over 70mph, but I'm fairly confident we don't see it holding 10 long if/when that happens
Polo08816
viven44
Dallas, TX
Looks like the Corvette cranks are made in the NY plant and it sounds like the truck/SUV crank production was moved Mid-2024 to the NY plant.
jfoj
I was aware of the 6.2l cranks being made in Mexico and assumed GM moved production back to the US.
Not sure the video has a lot of solid smoking gun stuff at the moment, but usually inside sources need to feel out the presenter to make sure they are comfortable what info they provide. Hopefully there may be some follow up with more meat and potatoes.
viven44
Dallas, TX
Yep, just relaying my "glass half full" view of that video. "glass half empty" view is that the video didn't tell us too much than we already knew or could have guessed, except to expect more in the future.. good to have an insider
jfoj
Need to vet your source(s) and the source(s) need to have confidence in the presenter. Tip toe around a bit until both parties are comfortable. Hopefully there will be more to come.
jfoj
Interesting links regarding final crankshaft polishing requirements and procedures. The thinner or lower the viscosity the oil, the smoother the crankshaft bearing journal finish needs to be. Additionally heavily loaded engines also need an extremely smooth final crankshaft finish. Most articles reference Diesel engines as heavily loaded engines, but the way the 6.2l engine is loaded at highway speeds, it effectively sees loading similar to a Diesel engine. Rougher crankshaft final polishing does not do well with lower viscosity oils. Additionally the wider the bearing clearances the higher the oil viscosity needs to be.
Based on the 6.2l Recall info and other info available, it appears that the main culprit of the 6.2l engine bearing failures had to do with final crankshaft finishing being too coarse and therefore causing problems with the 0W20 engine oil. It seems the majority of the 6.2l engine failures were under high loading conditions, Low RPM/High Torque situations at highway speeds for longer periods.
The crankshaft surface finish being too coarse along with possible increased bearing oil clearances is why GM is changing to 0W40 engine oil for Recalled engines that "Pass" the noise and knock test using the knock sensor mounted to the engine block for the Pass/Fail inspection test.
Is the change to 0W40 engine oil on the 6.2l engines that pass inspection good enough to keep these engines alive for many miles? It seems to fall in line with what a rougher surface finish on a crankshaft would require, but has some damage already been done on these engines? I guess only time and mileage will tell, hopefully the GM Pass/Fail test and the 0W40 oil viscosity change will keep the 6.2l's that "Pass" the noise and knock test alive for many miles to come.
Mahle Crank Polishing
Grish Crank Polishing
Grish Why Crankshafts Need Polishing
Crankshaft Journal Finish
Modatek
RG23RST
SPS says strategy code for 5.3/6.2 TCM is the same so there won't be any difference in shifting. 10th is your prime highway gear and either configuration will stay there at steady speed up to 80mph or higher when not trailering. Lugging the engine is bad for emissions so that's why you see any modern automatic downshift if you breathe on it at all.
It's quite funny to see some members on here talk about the 5.3 like it's a 2.5L 4-banger. Torque demand is torque demand and the 5.3/6.2 aren't much different at all in VE mapping. Sure the 6.2 has more headroom but on the highway both are wheezing through a mostly closed throttle valve.
Know what engine also has no trouble maintaining 10th gear from 58mph up to 80+? The mighty 3.3L V6 with 265lb ft of torque used in newer F150s that got paired with the 10R80.
BadDaddy2003
