Help me understand ...
Mean_Green
Tire store was able to get the alignment in enough to meet specs, but they told me something I didn't understand.
Something about a knockout that had never been removed to be able to adjust the caster and camber. My non-mechanical mind doesn't understand why that would be necessary in the field and not taken care of during production and assembly.
wjburken
Eastern Iowa
I believe this thread from GMT400 discusses what you are talking about.
Mean_Green
Mean_Green
Mean_Green
Mean_Green
This is at least a better explanation, but I still can't see any pictures.
wjburken
Eastern Iowa
A quick search for GM OBS Caster Knockout yielded this picture. Does this help?
GMT800 2005 Tahoe Z71
Navy Supporting Member
There are knockout slots on upper control arm adjustment cams, that allow an alignment shop to make finite camber and caster adjustments. The "knockouts" are there for adjustments that are made after the truck gets mileage on it and the bushings settle and therefore adjustments/settings change. When the truck goes down the assembly line everything is centered and assembled faster and easier with it all together. When it is time for an alignment and adjustments are out of spec, then the camber/caster adjustments cannot be made unless the knockouts are removed and cam kits installed.
In @wjburken pic above, once the knockout is removed and the egg shape cam kits are installed, the cams rotate and rub against the tabs and allow the upper control arm to move in and out and hold in place when tightened.
The alignment shops will charge extra to remove the upper control arm bolts, knock the tabs out and then install the egg shaped cams and then they stay there for the future alignment adjustments.
The age of your truck indicates that alignment techs that aligned before were lazy and did not want to do the extra work. They "set the toe and let it go". The current alignment tech is doing what should have been done a long time ago.
in other words it's never "needed" adjustment before, sometimes it's good for a long time
I would have to see the previous alignment printouts but so many times the caster/camber are "within the green spec parameters but one will be negative and the other positive and far apart on adjustment. "Set the toe and let it go".
Mean_Green
Mean_Green
They said it was pretty close and the 10+ years old tires didn't really show any inner tread wear.
I may have wasted $130 on the alignment but with $800 in new tires, I figured I might as well have it done.
IMO, an alignment is never wasted, unless performed by inexperienced/lazy Techs.
dizhai
