08 Tahoe 4l60e rebuild
osirus5164
I'm working on rebuilding a 4l60e out of our 08 Tahoe. Teardown went well for my first time, putting together a parts list, and I'm inspecting a few hard parts that barely concerning to me. Posting pics for reference as soon as I figure out how to haha
j91z28d1
I don't pretend to know anything about automatic trannys but I seem to read looking at drums for cracks and stuff more so than gear teeth issues.
seems there's a few common things to look for damage in each different tranny. I don't know what that is thou on yours.
osirus5164
osirus5164
Yeah, I used his teardown video for reference. I just am not sure about if these are within any sort of tolerance. I've never seen known good parts as this is the first time I've taken one apart
petethepug
Michael
SoCal
You go man. Slush boxes, or transmissions in general are not in my scope. Things have come a long way since there were only Haines manuals.
osirus5164
osirus5164
Took apart the pump. Looking to order the boost valve but I saw there's more than one option. Will bust put the calipers when I wake up but just wanna make sure I'm measuring it properly
osirus5164
osirus5164
Looks like part no. 77898e-16k. Do I order new springs or are they reusable? That pin that sits inside the body behind it, is that reusable as well? Thanks
If you're asking someone in particular, tag that member in your message:
Tip: if you want to tag someone, either "reply" to that member's post (like I did here with yours) or 'tag' him using the "@" symbol and start typing the member's name. A picklist will come up and you can select the name from that. If you don't use the reply or tag function the member may not see your post, and won't receive a notice that he was mentioned.
osirus5164
osirus5164
Nobody in particular, I've only been a member for a few days so it's kinda an open question. If you're familiar, feel free to enlighten me with any tidbit of information as this is my first attempt. If all goes well, I'll take on a second 4l60e, maybe even a third
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Good luck, and thanks for sharing!
rdezs
Have confidence. 8 years ago I tore into my first automatic transmission, a turbo 350. Picked up a manual on rebuilding it to take some serious horsepower. Took my time, went page by page. A lot of it doesn't make sense on how it works, so when you put it into service and it works perfect....priceless.
osirus5164
osirus5164
@NickTransmissions picking your brain just a bit. I've been reading a lot about stepped cut rings being inferior to solid Teflon rings. I'm torn between picking up a stepped cut set and trying out one of the lower cost optioned sizing kits and seeing how it goes. Would the quality of those sizing kits be bad enough to warrant just getting a stepped cut set? Also, is that wave on the splines of the indicative of some other damage I should specifically look for? I didn't see any waving on the planetaries but am definitely curious.
Ossipeelake
