Can't Remove Hitch Pin, Not Rusty
NOT My Bro-s Taho
Winneconne
I towed a (5 x 8-ish) single axle trailer 5 miles loaded with a Case 222 lawn tractor. It appears that the hitch flexed, and the formed end of the pin rotated down into the slot for the safety chains.
Is this a "normal" thing? Is the hitch that flexible?
I should be able to get it out by removing a little material from the end of the leg but do I have to?
Grady_Wilson
Wyoming
From the looks of the first picture, the pin was much smaller than the hitch pin hole.
It allowed it to move up and down, along with allowing the hitch to move inside the receiver.
This caused the pin to move upwards during the movement of towing and get inside the safety chain loop.
I would see if you can lift the hitch bar enough to move that pin up to rotate it out of the loop.
Or, you could just cut the pin and source the proper sized pin for the receiver.
PPV_2018
Molon Labe
U.S.A.
Putting some weight on it / jiggling it plus a BFH tap from the left side couldn’t break it loose?
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Are you sure the tow chain/hook didn't get too tight in a turn and bend the pin? Cut it off with a dremel or sawzall or something.
Maybe use a floor or bottle jack with a piece of metal stock to push/pop it up out of the hole somehow.
Geotrash
Dave
Richmond, VA
See? This is my kind of ingenuity right here. Whenever I encounter something like this hitch pin, my mind immediately goes to the biggest, strongest tools I have to get shit going the right way again.
If you can't fix it, force it. If it breaks, it needed replacing anyway.
homesick
The Best Me I Can Be
Navy Air Force
I don't think I'd reuse that pin, regardless of everything else.
joe
hillstrubl
I'd spray some white vinegar in there a few times, then penetrating oil and start whacking it with a 3lb hammer. ... or just cut it off.
Once the pin is out, do a careful inspection of the holes in the hitch. If the pin was too small to begin with it could have been wallowing out the holes all the time it was under towing use.
N
NOT My Bro-s Taho
Winneconne
Thanks everybody for your observations and suggestions, Grady_Wilson pointed out the obvious that I missed: wrong pin. I was in a hurry (never happens to anyone else, right?) and couldn't find the bigger drop hitch that had the pin in it. So, I grabbed the next hitch and the pin out of a small hitch for my VW diesels. After I got the hitch and pin aligned, it popped out with a minimal love tap.
As for the rust, welcome to the rust belt. When the material coatings and everything got pretty good a few years ago, they switch from rock salt and sand to a brine solution. This one is pretty clean for this area.
JamesinAbilene
