How to get this off????
BOSS
The People's A D M I N
Dallas
How does this rear assembly part that the studs thread into come off the axle?? One of my studs has stripped out
Thanks in advance
BOSS
BOSS
BOSS
Dallas
Some call it the circular lug plate? Is it pressed into the bearing????
Lately I've had nothing but a bunch of questions/problems for this board....sorry
BOSS
chistoso
Arizona
It's the entire axle shaft right? Why do you want to remove it? Is it to replace lug studs?
HMFDZ28
Hunt Sta, NY
The lugs are pressed into the hub... you can hit the old one out with a hammer. To get the new one in just take the lug and slide it in... take a few washers, gease them and the threads of the new lug. Stack the washers and then using the lug nut tighten the lug till it sits flush with the back of the back of the hub plate.
BOSS
BOSS
Dallas
HMFDZ28
Hunt Sta, NY
If you have to pull the Axle out then you need to open up the diff carrier and pull the C-clip off to be able to slide the axle out.
BOSS
BOSS
Dallas
I got the new studs in....I pulled them in with a lug nut and one of them stripped the **** out on me inside the stud plate
BOSS
BOSS
BOSS
Dallas
Am I explaining this right? I'm not the most mechanically inclined
B
---------- Post added at 04:04 PM ---------- Previous post was at 04:03 PM ----------
Thats a spacer... that will not cure your problem. Just change the stud.
I did replace the stud, it's stripped out....i pulled it in with a nut and it stripped...and now it's fuckng stuck LOL
BOSS
---------- Post added at 04:08 PM ---------- Previous post was at 04:04 PM ----------
Isn't that an adapter with the stud plate too?
HMFDZ28
Hunt Sta, NY
They do sell oversized studs for that purpose. The threads are the right diameter but the part that goes into the hub is slightly larger.
Its not an Adapter... its part of the Axle.
BOSS
BOSS
Dallas
So this part circled in red doesn't come off to allow me to take the stud plate out and replace the stud plate with a new one like in the picture?
chistoso
Arizona
no. its part of the axle shaft. you should be able to knock it off with a hammer and pull it from behind the plate..
BOSS
BOSS
Dallas
I just made a comment to my wife:
"Look how big my pipe is honey"
BOSS
BOSS
Dallas
If there wasnt a lug attached I could....cant get a grip on it from behind
B
chistoso
Arizona
B
Are we thinking of the same thing? What are you trying to acomplish here? I'm thinking you want to remove a stripped stud..
BadDaddy2003
