2016 Tahoe Z71 - Gauges turned off, kept driving OK. Shut off now won't start?
ezmoney1981
Will do my best to keep this concise and share pertinent info only:
I was driving my 2016 Tahoe Z71 with 111,000 miles home from 2 hours out and 100 miles. I stopped for gas about half way, filled up, no issues.
About 10 miles out, I noticed all the gauges were full lock left, reading 0. All of the sensors flagged alerts. Wipers, parking, ABS, airbags, etc. Center console had carplay on, and kept working. I thought that's weird, maybe I should stop and turn off the car, and when i turn it back on it will effectively "reboot".
I pulled off the freeway with 5 miles to home, pulled over to a safe spot with a shoulder and what not. Turned the vehicle off. When I went to turn the vehicle back on, nothing, some tapping (not clicking like a starter), and the dash did not light up.
AAA battery car came, checked battery, which was good. We both assumed it was a bad alternator.
Waited for the flatbed, with no juice, he couldn't even get it to move in to neutral. It was that dead/non operable.
Got a new alternator in preparation. Removed the old one, took it to O-Reilly to test it, they said it tested GOOD. Shit.
Pulled out the battery, tested it, 12.8v, a little low but also GOOD.
Checked the big fuses, GOOD (as far as I can tell).
Tried to connect a cheap OBDII reader I have, shows 0 codes. Great.. Also notice the climate info is in Celsius? Weird.
Open to any and all ideas!! Not good.
Big Mama
Virginia
I had a Sierra do the same thing. Turned out to be an overcharging alternator that toasted the battery. When I stopped to get it check Auto Zone said both were good. When I got home to my own testers is when I found the issue.
View attachment 448878View attachment 448879View attachment 448880
your first clue if you haven't fixed this already is you have no voltage, so that means one of more of those battery top fuses may have a took a dump or one of the cables connected to it are bad. or you may have a really bad ground somewhere, you need to get a meter out and start checking starting at the battery.
E
ezmoney1981
Good to know, I will swap the alternator and see what happens. Nothing to lose.
if you have key on, engine off and it shows 0 voltage then your issue is not the alternator, if you for some reason suspect it could even remotely be a bad alternator then simply unbolt the charge cable and try again. key-on, engine-off. you should see 12.xx on the gauge and thru the obd port with a scanner.
IF THIS IS THE CASE AS NOTED ABOVE (no voltage)
then go take your meter and check each of those fuse outlets on the battery top, each has a different rating i.e. 175a, 80a, etc, etc
if one of more of those are burnt (no continuity) then the vehicle may only get partial power, so you may have interior lighting but no power to the ecm, etc
those fuses are not serviceable you have to replace the whole unit and it runs about $120.
AND if one is burnt you need to figure out why, before you blow $120 by bolting up a new one and repeating the same end result.
E
ezmoney1981
Good info. Thank you. You know I did have to get a new bumper a month or so ago. Someone hit me at the duck club. Caliber collision swapped it out. I noticed some mud pulled one of the sensors loose. Could this potentially be a culprit or is the power there insignificant to this specific issue most likely?
depends on which sensor..... maybe post up a photo, the power on these k2's is split up from the battery top fusible link, so if one of those points burnt out you may see one thing works and other things no-go
found out myself the hard way when a audio amp I was installing was bad out the box and fried the system.....luckily the fusible link did it's intended job and nothing else was burnt up in the process.
E
ezmoney1981
Swapped the alternator and fully charged the battery. Did not solve the issue.
I did try the remote start and the car flashed through all the “things” on the dash. Never started though.
Going to let a mechanic take it from here. I’m not proficient enough in the testing of all the electronics to chase this down.
LanceD
AZ
I've been having similar issues sporadically with a 2018 Tahoe PPV. All of my gauges drop to zero, warnings for Stabilitrak, steering assist, No power steering, transmission starts shifting funny, and the engine seems to be much weaker. If I shut it off, it will not start again, only a click sound. The OBD port has no power to read codes. If I leave it alone for a few hours, it will start fine and everything is back to normal.
I've got 2 batteries with the isolator and it works properly. checked all of my battery connections and all are clean/tight. checked continuity on most of the big cables and they are good. Would sure like to get this figured out.
LanceD
AZ
Checked codes today after letting it sit overnight and got:
U0101
U0073
After I started the engine the U0073 went away but I had to clear the other one. All of the problems were gone too.
E
ezmoney1981
OK, here’s your update:
I decided to call AAA and have them tow it to a repair shop. That repair shop is actually caliber collision because I have a hook up there. They do have mechanics on staff.
Of course, the AAA guys, one was in training, and the other was the seasoned vet, assumed I was an idiot and told me they could probably get it jumped and going again. I sort of laughed and told them OK sure feel free to prove me wrong. I would love nothing more.
They wasted about 10 minutes of their time and got to the same place. I did pretty quickly.
I did tell them that I just had the bumper replaced and I did see a cord hanging out the back rear the other day. But I wasn’t sure if that had any relation to anything.
The apprentice went back, got on the ground, and looked underneath and found that harness, only to realize that it had a considerable amount of melting.
Seemed pretty obvious that would be the issue, they towed it back to caliber anyway since they did the bumper repair I needed. They’ll probably cover it under warranty.
What is interesting is that? I probably drove this Tahoe for the last five years to my Duck Club and it constantly got mud caked in the same spot never had an issue though.
I am guessing that when caliber replaced the bumper that had a big dent in it, that they forgot to clip the harness up higher or something, and when I took it hunting again, all the mud splattered and it fell down - thus either catching on fire or being so hot that it melted being near the exhaust pipe.
Candidly, I was surprised that a wire harness that far back could disable the whole car. Interesting right?
Waiting to see where it goes will up to you update you all later.
that's pretty much a known defect on the k2's, the module/harness is held on by a FACTORY plastic bracket/clip, that breaks and then allows the thing to hang on the exhaust pipe and melt the crap out of it.
why there has not yet been a recall on it I don't know
sealandsky
Minneapolis, MN
My money is that there is a bad ground, or dirty positive - or both. I had the same thing happen. There are several leads to chase, but remove and clean each one.
BadDaddy2003
