Not today, but last week came out of work and spotted drips on the pavement under front end. Coolant! Overflow tank was almost empty. Drove around corner to Advance and picked up a jug and filled it. Made it home and the next evening put pressure on the system. Small crack in the radiator up high on drivers side just under the hose. New radiator from Napa installed and all good now!
Very common area to crack. Mine also cracked there.
viven44
Dallas, TX
Not sure where to share product recommendations, but I finally found a great marker to mark driveshafts, etc ! I have relied on other types of markers such as whiteout ink, but this one tops it all in clarity. It works just like a crayon, but one made of solidified paint.
I have always wondered what they used to mark vehicles at Auctions, it has got to be this product (or similar) below
Amazon.com: Sakura Solid Paint Markers - Permanent Marker Paint Pens - Window, Wood, & Glass Marker - Yellow Paint - 1 Pack : Arts, Crafts & Sewing
Example below.. marked my greasy driveshaft effortlessly (Getting ready to replace transfer case output shaft seal on one of my clunkers)
DRLexpress
Thanks for the info. Where do I find that code. I am scared to touch mine because they look original and not leaking. I had better get some on the way. RA lists both 800-413HP and 800-414HP for mine, I take it I need 1 of each.
@Tahoe14 said where to get it:
@DRLexpress, don’t forget about the extra 5% off at Rockauto using the code, “Preferred Vendor Sales” section under the “Site News” section at the top of this forum site for the code.
Or click on this thread and go the last post you can find for a code that hasn't expired:
Note that the OE tees have slightly different angles for the rear heat hoses. I don't know if Dorman has the same.
Tahoe14
Central Fl
Home page for this forum, top of the page “site news” then subsection “preferred vendor sales”. It will show the newest code on the last page, scroll through the section maybe the first page and it will show where to enter the code on Rock autos site.
mattbta
Frisco, TX
Looks like they have two models as OE does. Intrigued, however I just bought GM tees a month ago to put in. Might still have to try these.
EDIT: For $45 on RockAuto - why not? I'll keep the OE in case they don't work out.
BigDogYJ
Earth
Replaced the parking brake release handle/cable on the wife’s 04 Yukon. Couldn’t locate a Gm original. Settled for some knockoff on Amazon. Seems decent. We’ll see how long it lasts.
At least it’s a simple job and when it fails you can still release it by hand fairly easily. These are the only things I don’t mind trying a cheaper alternative with.
mattbta
Frisco, TX
I did the same with the hood release - no name on amazon was quicker.
dps01
Senior Member
Navy Supporting Member
N. TEXAS
Enjoyed a nice day in North TX.
Changed 22 year old bulbs to LED…DRL, turn signal, backup, and brake lights. Installed a LED compatible flasher… without loosing a bunch of skin on the hands :D.. pleased with results; no hyper-flash… life is good.
In the process, broke and repaired mounting tab on tail light assembly.
strutaeng
Dallas, Texas
My 99 Silverado has been leaking at the tailshaft extension housing since I swapped that transmission. I hate oil leaks. So today I went and bought a seal replacement. USPS was supposed to deliver my crankshaft seal for our 3.6 Pentastar minivan that's getting a wobbling harmonic balancer replacement...but of course, they are late. So I decided to paint my driveshaft to waste time... SMH
Korbin_A
