Spare FPCM (Fuel Pump Control Module) WISE IDEA!!!!
PPV_2018
Molon Labe
U.S.A.
Interesting does anyone have any insight as to why are the part numbers for this unit being superseded already so frequently ???
I mean i know it’s common for part numbers to be superseded over many years time maybe when raw parts are sourced elsewhere and/or when small changes are made to said part or for other reasons, but like 5+ PN’s the same exact part, for just as many model years seems weird af.
J
jfoj
Just a guess, different vendor(s) and/or design improvement(s).
Clearly there have been problems with some earlier versions of the module as there was at least 1 recall.
Marky Dissod
... any insight as to why are the part numbers for this unit being superseded already so frequently?
GM looks for ANY excuse to 'update' part numbers -
different maker / supplier / manufacturing plant, even of an otherwise identical part
different / new production run (otherwise identical Allison trans control modules have different part numbers depending on when they were made, by Allison)
in short, almost anything you can think of as an EXCUSE for a new part number ...
StephenPT
St. Helens, OR
FWIW - I was on RockAuto today ordering oil and filters - took another look at the FPCM and it's showing as being available to order again - albeit a 1 day delay...
PPV_2018
Molon Labe
U.S.A.
But why though? Part number confusion brings customers to the parts counter giving dealerships an opportunity to upsell parts and service ? lol maybe that’s the cynic in me but..?
Marky Dissod
Ever get the impression, that if a group of people ACTUALLY wanted to TRULY solve the problem they say they exist to solve, they'd be out of business?
So even if they earnestly try, they still keep failing due to the unconscious knowledge that truly solving the problem is their very demise?
It's not THAT paradoxical. It's more like an adolescent ouroboros trying to fatten itself so its tail won't fit in its own mouth when that day comes.
The point is, the 'extra' part numbers are for GM, NOT for us. GM knows what the extra part numbers mean TO THEM,
while we are slowed trying to figure out which part number we actually want or need.
PPV_2018
Molon Labe
U.S.A.
Your response now has me pondering corporate what-ifism. And life. Thank you.
J
jfoj
Just got notification from Shea Chevrolet that mine shipped.
Glad your shipped, hopefully it arrives in short order. My #2 backup just arrived this morning. So I will be well suited to help out family, friends, forum members or even a stranger stranded on the side of the road.
Now I have to save my penny's for a spare 6.2l crate motor to have in stock when I need it!
Never hurts to be overly prepared!
DontTaseMeBro
I ordered a second one from Summit Racing for a lot less, $35 before shipping. Will be curious to see if it ships next month(eta for when they'll be available). Not sure I wanna keep 2 on hand so I may just sell one lol.
BTW, for those curious, the one that got shipped just is coming straight from Flint, MI. Being drop shipped directly from GM probably.
DocDoug
Its not if the module will fail, but when IMHO. Either due to component failure, solder joint problems or water intrusion into the connector.
I cannot say 100% that the module needs to be programmed, there was all sorts of info that my 2024 needed to be programmed, but it did not need to be programmed.
I think your FPCM is clearly a different part number from the current models and may be around $100 depending on where you find it.
There are 2 problems when the unit fails.
1. Finding the correct FPCM quickly and easily. Late and night, weekends in the wild, who knows. Buy one and have it in the truck.
2. Programming, does it need it?? Buy it and try it. It will either work or need programming. If it needs programming, you at least have it on hand and can shop around and find someone to program it for a spare, or if you get stranded and have the part, then you just need to find a shop with a more advanced scan tool that can program the module.
In my area, this would be less than a cost of a tow job, plus you would likely need to pay list price for the part, labor to install and programming. Quickly adds up to a $500-$750 job and at least a day or more. Can't even put a value on the PIXXed Off wife!!! If mine fails, it will likely be in the midst of a 2.5-6 hour trip as we take these pretty often.
Gateway came through! Arrived two days ago! I plan to test it on the truck to confirm that it works. Once confirmed, it will be placed in the rear jack area for standby! Thanks again. Cheap insurance.
DontTaseMeBro
Just got mine from Shea Chevy.
It is a 13554821. Looked underneath my Yukon and it has the 13537053 module.
DontTaseMeBro
Just did a test replacement on mine. It fired right up. That being said, it triggered a CEL code - P0627 “Fuel Pump “A” control circuit/open. I could not clear it with the Carbyte module that I have plugged in. Put the old module back, vehicle fired back up as well. Still could not clear the DTC. Drove the vehicle for about 10 miles. Turned it off. Turned it back and CEL was gone. Something to keep in mind. Also, I found out that remote start gets disabled when a CEL is triggered.
J
jfoj
CEL is not really an issue. Depending on the state of the vehicle when the module is changed, it could possibly trigger a code. When I originally swapped the replacement module in, the vehicle had been parked overnight and I purposefully left the keyfob in the house rather than have it in my pocket so when I approached the vehicle it would not "wake" up. once the module was swapped, I walked out with the keyfob and pressed the unlock button on the keyfob while standing next to the left rear of the vehicle. I heard the fuel pump cycle when I unlocked the door so I knew things would likely be fine, no programming vs what was all over the Internet.
After starting and allowing the vehicle to run for about 10 minutes, I fully shut down the vehicle so the dash and electronics were shut down, swapped module, no issue.
If for some reason the vehicle was not in a full shut down state, there may be polling of some modules and this may have been what triggered the CEL/code.
As for CarByte, I believe the OBDII App that works with it is OBDFusion or an OE version of OBDFusion. I know this App quite well, one thing that OBDFusion tends to limit is being able to clear codes while the engine is running, even if prompted to clear codes with the engine running, it may not clear them. Also with the newer CAN vehicles, it is possible that the CAN system limits under what conditions the code can be cleared.
In any case, OBDII standard is designed to clear codes automatically after a specified number of Start/Run cycles, depending on the code, this could be a few Start/Run cycles up to 10-20 Start/Run cycles if the code does not reappear the CEL will go out if the fault has not been seen again but there may be History trouble codes stored.
StephenPT
St. Helens, OR
Did you replace it with the battery still connected? As @jfoj mentioned the vehicle will be in an “awake” state for about 10min if you unlock a door, open a door, etc.
Likely the ECM saw the disconnected fuel pump because it was “awake” and after completing a drive cycle and not seeing the fault anymore, it reset the light.
Yes, a CEL for any reason automatically disables remote start.
DontTaseMeBro
Yup sure did. OP stated that he replaced his without touching the battery but didn’t say whether or not it popped a code. Also, I did not wait 10 minutes for all of the electronics to power down.
Either way, no harm no fowl. Just wanted to point out that if someone were to experience an unexpected FPCM failure, they should expect a CEL if they don’t wait 10 minutes first before replacing the module. Under normal circumstances I would have disconnected the battery(as I usually do for these types of things), but I wanted to do a dry run emergency replacement.
As far as remote start, it was kind of interesting cause I’ve never had a CEL on a remote start equipped vehicle so I was caught off guard for a second.
DontTaseMeBro
Carbyte displays a warning saying not to clear codes while the engine is running. Personally, I’ve never done code clearing this way with any OBDII scan tool. I tried to clear the code with accessories on only. I heard the relay clicks and the chime but the code stayed. So ya, the CAN system prevents it from being erased.
J
jfoj
DontTaseMeBro pretty much took the same approach as me, did not want to worry about disconnecting the battery because if I was on the side of the road, I would not bother. So as you found, clearly in some instances it may trigger the CEL/code. But triggering the CEL/code should not impact the way the engine runs, possibly some other codes might, but not likely for the FCPM.
Interesting about the Remote Start, will need to test this to see if I can replicate the Remote Start being inhibited due to a CEL.
blanchard7684
Senior Member
High quality info. Thanks.
DocDoug
Just did a test of my new module. (I didn't disconnect the battery.) It started and ran fine! Swapped back the original module and I too have the CEL on. I guess I have to do the drive and shut down then restart to clear it.
UPDATE - CEL is off.
On a side note, the little red secure tab/pin that is removed from the connector to disconnect the module, cracked. Can these little red pieces be replaced and if so where can they be obtained?
Thanks!!!
johnsonwillie199
