What Transmission do i have
JustPlaneMike
I have a 2008 GMC Yukon Denali with a 5.3. The shifter is
P R N D 3 2 1. How can I tell if I have a 4L60E or a 4L70E. Thanks
Marky Dissod
Inside your glovebox you should find a sticker with many 3 character codes on it.
Look for either M30 (4L60E) or MYC (6L80E).
MD8 = 700R4 / 4L60 (no 'E')
M30 = 4L60E
M32 = 4L65E (4L60E Heavy Duty)
MD6 = 4L65E (what is 'PTU'?)
M70 = 4L70E (Super Duty) (somebody with a TrailBlazer SS, please check their RPOs?)
MT1 = 4L80E
MN8 = 4L85E (Heavy Duty, think 6.6L DuraMax)
MYC = 6L80E
MYD = 6L90E (Heavy Duty, think 6.6L DuraMax)
M5U = 8L90E
MQE = 8L90E with 'improvements'
MF6 = 10L80E
MX0 = 10L90E
I think you typed the year wrong, a 2008 denali would not be a 4sp, it would be a 6l80 6-speed and it would say PRNDL
nbs 2000-2006 they had the 4l60, unless someone changed it.
NickTransmissions
Sin City
The transmission bench
You should have a 4L70E if your shift indicator has that pattern. Look for M70 RPO code in your glove box though as @Doubeleive said, you should have a 6L80 (RPO=MYC) for that year.
JustPlaneMike
JustPlaneMike
@JustPlaneMike this is posted in the 2000-2006 section. Check your year and put your year, make, model, and trim in your signature so it's always in your posts.
Then we can move this thread if needed. You'll get more accurate answers posting with good info in the correct section.
Is there a way to add signature and save it or do i have to enter it every time? Ps I searched for an answer before posting and could not find one, thanks
JustPlaneMike
JustPlaneMike
Thanks but I don't see it, here is a pic
JustPlaneMike
JustPlaneMike
Thanks, Thought it was a denali but double checking since your reply i just have a Yukon XL 1500. It is a 2008 with the D321,
JustPlaneMike
JustPlaneMike
M30 = 4L60E
MT1 = 4L80E
MYC = 6L80E
M5U = 8L90E
MF6 = 10L80E
MX0 = 10L90E
Fantastic excellent reply , THANKS found the M30 code in the glove box.
Click on your username in the upper right-hand corner of the screen and select "Signature." You can edit it there, and it will show up on every post you make.
Dh1280
