New engine wiring harness
Schojo
I have a 2004 Yukon 5.3L 2WD. I’m having difficulty finding places for a complete engine wiring harness. We redid the heads on the engine and were being lazy and didn’t remove any wires, just kinda pushed them out of the way. Now we can’t figure out what wires are bad they’re the original wires so we’re just wanting to redo whole thing only issue is, I can’t find anywhere that I can buy a complete wiring harness (idk if that’s the right wording for it) we’ve called around a few places, even tried a few pick and pulls bc why not and still no luck. Anybody have any resources?
strutaeng
Dallas, Texas
You can just remove the loom, inspect and repair whatever wires are damaged, then install new loom.
I removed the entire harness from my 06 to reapply new loom because it was all crumbly and missing in several places. But removal is kinda of pain, unless the intake/heads or entire engine is out.
I would favor you keep your harness because they made slightly different configurations, drive by wire, drive by cable, some had EGR (some HD trucks, at least), then there's the red/blue vs green/blue ECU connectors... maybe I'm generalizing too much the entire GMT800 lineup here tho.
Edit: here's how I redid mine last year: https://www.tahoeyukonforum.com/thr...-engine-transmission-wiring-harnesses.143808/
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
@915_Tahoe
S
Schojo
I got ahold of GM, I was told they no longer sell the engine wiring harness part 15124981 and that it’s discontinued… now I’m really at a loss on what to do?
S
Schojo
Dumb question: why do you think the wires are bad? What symptoms are showing up?
Nothings a dumb question, Yukon won’t stay alive. I’m not sure how to describe it. First time it happened, car was fine after redoing heads etc for about a week and then I went over a rough-ish bump (was just like a steeper than normal speed bump) car immediately died no sound just off. Wouldn’t turn back on, it cranks but won’t start up. We replaced all that the diagnostics were showing needed to be fixed, A few sensors and even replaced wiring for one but still didn’t fix the issue. Car still won’t start but will crank and it’s just draining the battery when we do try. I’m not sure if that answers your question or not
RST Dana
OH
It will need fuel and lightning to make things go up and down on their own. Have you checked fuel supply/pressure, and plug wires to check their sparkiness?
Sam Harris
Sounds like you need a standalone ECU now… perhaps a Holley solution..? And if you decide on that, than obviously, you need to take full advantage of its capabilities. I’m pretty sure those nice standalone Holley devices have additional control capabilities for things like extra “a/c compressors”, and whatnot… :naughty:
alpha_omega
Michigan
What did you figure out?
johnsonwillie199
