Black Bear Performance review after several months - engine, trans, AFM/DOD
LurkingLuke
WA
Been running my tune for a few months now (2013 Denali 6.2). Overall I'd say it's a great value and a satisfying purchase. A few points in no order.
CUSTOMER SERVICE: The guys are all great. They pick up the phone right away, respond to emails, and to their credit they never once displayed any frustration with me, even though I pestered them with way too many questions about installing the tune. A+
INSTALLATION: I'm not savvy when it comes to automotive repairs and modifications. The instructions, though thorough, confused me. BBP included everything including the kitchen sink. There were many, many details, including lots of "you might get such and such a code; if you have this model of engine or trans, you will have to do it a little differently; depending on which version of our product you have, you will see something different and you will have to press a different series of buttons." It seemed all jumbled together. In the end I finally made sense of it, but I found it difficult to figure out which thing applied to me at which time and what action I was supposed to take. I couldn't have done it without the patient customer service.
ENGINE PERFORMANCE: there was no night-and-day improvement I noticed. Mashing the throttle to the floor felt no different from stock. However, in partial throttle application, or 99% of driving, I felt a modest but noticeable swell in torque. I'm guessing that the power gains are not so much in peak power but in average power. Picturing a torque/HP graph, there's more surface area under each curve. I'd compare it to a car that offers different driving modes, like Sport, Normal, and Economy, only it's always in Sport.
TRANSMISSION PERFORMANCE: same analogy. It drives like it's in Sport mode. Kicks down sooner and holds on to revs a little longer before upshifting, yet if you're gentle on the throttle, it's not high-strung but relaxed. Two anecdotes:
(1) in making a turn from a stop, the stock transmission shifts almost immediately into second gear unless you're aggressive on the throttle, forcing you to either startle your passengers with sudden acceleration or to be in too low a gear once you've completed your full 90 degrees. With the BBP product, it's always in the "right" gear.
(2) going up a steep(ish) hill each day, I need to downshift a gear or lose speed. With the stock TCU, pressing the gas a little just made the engine groan louder under the extra load without helping keep my speed up---but if I pressed any harder on the gas, it would jump down two gears, jerk the vehicle, and wail at high RPM until I eased off and got the truck into the gear it actually needed. With BBP's tune, nudging the gas gives me a swift but gentle kickdown, just one gear, and puts me in the right power band.
AFM/DOD DELETE: works as advertised. The dash display which tells you your instant MPG and whether you're running on 4 or 8 cylinders now shows 8 all the time. Instant fix!
FUEL ECONOMY: contrary to BBP's claims, the trip computer shows about a 1-1.5 MPG decline rather than gain. And no, it's not because I changed my driving style and am hot-rodding around all the time. I just seem to remember getting about 14.5 MPG on average, and now see 13-13.5. Unfortunately, I never kept records from tank to tank, so I have no solid confirmation. Forgive the pun, but YMMV.
CONCLUSION: the truck now drives the way GM engineers wanted it to but were forced by the EPA to strangle the powertrain. I really appreciate it and know I will enjoy it for the rest of the life of the vehicle. Considering this, it was an excellent investment.
B-train
Thank you for the works burger review! It's nice to get a real world comparison written out. It's always good to get other people's input and perspective.
I've played with HP Tuners on my 2008 Denali, and used it for turning of AFM on my 2017. I'm no where near as good as BBP, but I do feel good about my changes that I've made to timing, shift schedules, and TCC. I will say that making the trans happier for the driving cycle does seem to take a little off the average MPG due to more RPMs between each shift. But, it feels so much better that it's worth it. I have also found that I can get premium fuel performance with a 30% blend of E85 and 87 fuels that yields what I was getting on regular 87 for MPG - approximately. Again, it's not an exact science, but the change in driveability is noticeable.
Learning the proper way to get rid of, or lessen, torque management is next on my list to play with.
Marky Dissod
... the truck now drives the way GM engineers wanted it to,
Also consider: your engine and transmission will very likely last longer between rebuilds.
Charlie207
LFOD, New Hampshire
Two anecdotes:
Yeah, that's my only lingering & fickle complaint, especially when coasting for .5 seconds. The gearbox code decides to upshift or something, because there tends to be zero throttle response, the it acts like it wanted to upshift to 6th, then back down to a lower gear I was in, and WHHAAAAM.... 4000 RPMs.
These engines have torque, and can stay in the same gear just fine. I wish there was a valid and bolt-in manual swap.
Marky Dissod
6L90E: . . . . . . . . . . . 4.03 . . . . 2.36 . . . . . . . . . 1.53 . . . . 1.15 . . . . . . . 0.85 . . . . . 0.67 (6.01 Spread)
This version of the T56 is harder to find than the one with the numerically lower gears that I would NOT recommend in an SUV.
T56: . . . . . . . . . . . . . . . . 2.97 . . . . . . 2.07 . . . . . 1.43 . . . . . . 1.00 . . . . 0.84 . . . . . 0.63 (4.71 Spread)
If you're willing to tolerate a 5-speed, the Tremec4050 is the Mexican alternative to the NV4500,
taking the NV4500's place in the American aftermarket as the latter becomes rarer,
largely because its shifts are less 'trucky' than the NV4500.
TR4050: 6.16 . . . . . . . . . 3.11 . . . . . . . . . . . . 1.71 . . . . . . . . . 1.00 . . . . . . . . . 0.76 (8.11 Spread)
LurkingLuke
LurkingLuke
WA
...coasting for .5 seconds. The gearbox code decides to upshift....
If you're talking about the stock trans, this surely is an EPA MPG thing. If you have the BBP upgrade, a tiny press on the pedal will fix it. Otherwise, stick it in "M", I guess? There's always a torque element in "torque converter".
Charlie207
LFOD, New Hampshire
I have their ECU/TCM tune in my 6.0, and had the same package when there was a 5.3 in it.
The problem arises when I touch the gas pedal; the throttle is dead. I could floor it, and it's as if every electron in the system took their mandatory 15-minute prior to break-coffee break, at the same time.
0.5 to 1.0 seconds later (an actual eternity when you have a dead throttle, merging into traffic) the engine comes back online, the transmission hunts/pecks back down to the gear it should have been in, and we're off.
It happens in Drive and Manual.
The torque converter has nothing to do with the throttle body going dead, as far as I can tell. It was replaced with a billet-backed unit over the summer, anyways, and works great.
It's just another reminder how terrible ATs can be. I would gladly work a clutch and row my own gears, even if it meant I had to move back to the Bay Area, and drive through rush hour traffic in San Francisco, yet provided steady & reliable connection between the gas pedal and the engine.
Marky Dissod
I have their ECM/TCM tune in my 6.0L, and had the same package when there was a 5.3L in it.
0. A cross-eyed demographic analysis of American civilian drivers, coupled with CAFE MpG 'goals', are pretty much killing off American manual gearboxes.
There are far more manual transmissions left in the rest of the world; they get comparable MpGs with only six speeds compared to our TEN speeds.
1. Either you did not complain enough to your tuner, or your tuner is being 'conservative / safe', or some combo of the two.
GM OE tunes electronic 'throttles' to respond to the driver in such a way as to discourage anything vaguely resembling enthusiasm.
If you're cruising at 25% power demand, and you IMMEDIATELY flex your foot to 50%, the throttle itself will likely do NOTHING for 0.3-0.5sec,
then it'll likely take 2.0sec to GRADUALLY yawn to 50% open,
almost as if the ecm&tcm are hoping your foot will back off before it has to finish giving you what you wanted
That's why aftermarket pedal pumpers are popular -
their initial response is much quicker than GM OE (even on a 'vette!), their eventual response is quicker than OE, and some even open further than GM OE would.
Your tuner is likely trying to protect your transmission, which is admirable and to be appreciated.
The price is that your foot's REQUEST will be delayed and mitigated SOMEWHAT by the ecm & tcm, although I think your tuner can 'squeeze' a wee lil bit more.
2. ...
Marky Dissod
2. As an 'intermediate' IronHead LT1 tuner familiar with other powertrains that came with 4L60Es,
I know that 4L60E vehicles had SEPARATE 'Normal', 'Cruise', 'Performance' aka 'Tow/Haul', 'Manual', and 'Hot' shift tables.
EACH and EVERY one of them painted as conservatively as GM could get away with.
These tables (and their less obvious companion tables) are where the 'vehicle's personality are most obviously made to suit the driver -
IFF the tuner is either self-inclined, or the client encourages the tuner to do so.
'Cruise' should be the most conservative if it is available.
'Normal' should be conservative enough UNDER 31%-50% TPS that a secondary driver might never notice that the vehicle has been tuned,
but should come alive beyond a TPS percentage agreed upon by the tuner and the client.
*'Tow/Haul' should be tuned to protect the transmission and the engine equally, assuming it is towing/hauling 1500lb OVER its max tow rating.*
*'Performance' should be tuned to help the driver race / beat the ambulance to hospital, possibly at the cost of powertrain longevity at the client's insistent demand.*
*If the vehicle DOES NOT Tow/Haul, the Tow/Haul shift table can be used as a 'Performance' table, at the client's request.*
(My Tow/Haul behaves pretty much a Performance shift mode.)
'Manual' & 'Hot' shift tables should be written with an understanding that all the other shift tables were written to avoid using 'Manual' and 'Hot'.
These should be considered 'last resort', to be used only in the event of mechanical faults ... unless the client desires otherwise.
Everything above applies to 4L60E vehicles with pcms.
Vehicles with 6L80E 8L90E or 10L80 have even more shift tables and even more less obvious companion tables,
so schidt gets an order of magnitude more complex, but the gist should be more or less the same.
For now point is GM OE tunes so conservatively, that ANY tuner improvements are deeply appreciated;
but that does help tuners not go as far as they can, knowing full well that their clients will notice and appreciate whatever they'll do.
I assure you that's not the case.
Granted / so stipulated.
Charlie207
LFOD, New Hampshire
but that does help tuners not go as far as they can, knowing full well that their clients will notice and appreciate whatever they'll do.Granted / so stipulated.
I just think this highlights one of the important shortcomings of "email tunes". There is basically no one nearby that can do a road tune or a dyno (rolling road) tune. So even though I log and log and log, the tuner isn't capable of experiencing the vehicle dynamics in person.
Marky Dissod
Once, I was lucky enough to tune a Fleetwood V4P (the only LT1 sedans that came with 3.42, for a 7000lb Tow/Haul capacity rating).
Because I REALLY wanted him to be VERY happy with it, his pcm did 4 round trips to make Goldilocks come correct.
Conedaddy
