Replacement autoride strut coil spring assembly
Rick10Tahoe
There’s no fully loaded OEM strut for the 07-14 z55 / z95 anymore.
Worth it’s weight in gold to buy the OEM parts a la carte. On a few boots and goodies I did MOOG & aftermarket. MOOG has replacement springs on R/A right now. Your current springs should be ok. Save them as they’re NLA if you don’t like the MOOG.
Dorman assemblies were having frequent returns for leaks since introduced.
@petethepug, I will reuse my springs unless a reason not too. I plan to get the oem strut and oem bump stop. Anything else I should replace? Thx
petethepug
Michael
SoCal
All the stuff on the R/A list, except the z95 & tpms sensor.
usdlawstudent
usdlawstudent
San Diego
Just as a quick follow-up, I went with the arnott passive front strut assemblies and rear shocks and they’re great…I’m not sure not as good as the oem autoride, but good enough for government work, and total cost was under $800 out the door from rock auto (DIY installed in 2-3 hour each pair) + I’m supposed to get $50 each for the rear cores from arnott (they buy those back).
I’d be curious to know if there’s a way to get some $$ from the front cores.
usdlawstudent
usdlawstudent
San Diego
Or put the front cores to good use. Otherwise it looks like they’re going in the trash
Grady_Wilson
Wyoming
There may be someone close to you that would take those old cores off your hands.
I would if I was close enough.
That would allow me to have a new set of front struts ready to go when I replace mine.
petethepug
Michael
SoCal
Arnott should buy the F&R back. If not, set them in a corner somewhere for a few months. They’ll buy em when they run low.
The Mag fluid in the z95 can not be shipped if leaking so, no shipping period on used Caddy struts.
Geotrash
Dave
Richmond, VA
If I understood you right, your originals weren't leaking or anything, right? I still have the originals on my '07 with 248K miles on them. If they're still in good shape, I'll buy them from you for $100 plus shipping, if you're willing to ship.
usdlawstudent
usdlawstudent
San Diego
Sorry, I would have taken you up on that, but they got taken out with the trash. They were really beat up. I don’t know what the exact issue was, but they would clank around loudly when I went over speed bumps, and they felt pretty unstable hitting bumps at high speeds on the freeway. No more of those issues with the Arnotts. I asked arnott if they’d buy the front cores, but they said no because they only rebuild the rears.
petethepug
Michael
SoCal
Somethings changed in the blend of materials they use in the bladders in air struts. I’m still on the original 2002 rear bags in the struts on my Audi allroad wagon. The fronts are on their 3rd or 4th set of Arnott.
Pretty amazing since it regularly carried the kids in the rear facing 3rd row. I wonder if the bladders were specifically blended with something known to make them last. This vehicle runs full air suspension front & back that’s height adjusted for load and speed. It gets worked.
MuttSr
Dorman is / was the only legit company making a loaded or complete set up like your looking for. 07-14 Escalade / Denali AWD and likely the 09> 2WD variant use the same front springs for z95 / z55.
You can get an OEM set up with AC Delco lifetime guarantee front z55 active struts for about $575 a side. I sent ya a pm with the info.
Don’t skimp on the strut bushings. Get the OEM GM version as the rubber material inside lasts a good decade and keeps the knocking away.
Do you think you can send me that info also. I need to replace my struts too, but I’m having a hard time finding the right ones.
Foggy
KS
In another thread this subject was discussed with the Arnott and Dorman
complete strut assemblies. I'm kinda in the same boat, but I don't think
that these 2 options really meet the OE design on the Z55 and may
not be a direct replacement
vrl2294
Can you send me this info? Really want OEM. I just paid $2,500 for dorman assembled front struts, back air shock absorbers and a compressor and now I'm reading bad reviews. I wanna return them before I open them.
petethepug
Michael
SoCal
Here’s what was sent…
There’s just a few of the Monroe aftermarket replacement z95 / z55 springs being clearanced out.
Here’s the z95 list of parts to make a complete loaded struts from Rock Auto. All you’ll have to do is order z55 struts vs z95 and the rest of the parts are the same.
Here’s the link to a pic of the part list on an excel document. The spring are almost gone forever so I thought you’d appreciate keeping it on the downlow.
Michael
'Aluminum / XFE NNBS Front Suspension Rebuild'
https://www.tahoeyukonforum.com/thr...-front-suspension-rebuild.146131/post-1854592
briannorris
