My driver's seat has developed play/slack in it. Fix?
KMeloney
My '01 Z06 had the dreaded "rocking seat" problem before I fixed it with an aftermarket kit. Well, my year-old '23 Denali's driver seat has just started to develop a tiny bit of slack/play in it where quick acceleration will cause it to shift back a hair (and then obviously shifts forward under braking -- although I can't feel that shift per se).
Anyone else have (and resolve) a similar problem?
(Sucks, 'cause my truck was just at the dealership for an oil change and updates just a couple weeks ago.)
KMeloney
KMeloney
Still under the 3/36 warranty? It’s hard to believe an $80k plus vehicle would have that. Were you able to check the rear bolts?
Have not checked any bolts yet. In the Vette, I think the seat rails would spread slightly, and so the back and forth sliding sensation was more of a "rocking" that occurred under acceleration and braking. This could be the same thing.
To be clear, I can't imagine that the whole seat is coming detached from the floor, or the seat from the mounting mechanism or something -- I suspect it's "slack" somewhere in the 4-way seat-adjustment mechanism.
KMeloney
KMeloney
In my Corvette (and probably in this truck), the issue wasn't a matter of bolts being loose. That would be an easy fix. It was a matter of slack developing in the motorized/multi-adjustment seat mechanism. I'm assuming it's a similar issue with my Denali seat.
Now that my adjustable seat-back bolster is also not working, I'm going to make an appointment with the dealership to have both issues corrected.
Durobans
