$64 for 8-Quart Full Synthetic Oil Change at local GMC dealer
tom3
Usually with our 5.3 the 8 quart fill up leaves it about 1/4 quart low. Close enough for me, 8 quarts is kind of a 3 qt. waste anyway.
fondupot
South Carolina
Common misconception, but the top of the dipstick hash marks doesn't technically mean "full" anywhere in the hash marks is technically OK to operate the engine. So wherever it lands after you put in 8 quarts is your "full" level. What you want to watch for is when it starts dropping from your full level, or is below the hash marks, or if oil doesn't even register on the dipstick, that would constitute a low oil condition. And always check oil when it's been sitting for over 2 hours on level ground. Ideally, checked overnight when all the oil has drained down to the pan, that will give you a true reading of the oil level.
blackelky
“Missing tie rod?” Hmmm I would think you would notice that the first time you tried to drive it. Cause it is not going to travel very far without it……
I noticed it and just assumed it was the crap rough country front suspension. I rectified it and replaced it with bilstein 6100 coilovers and heavy duty adjustable tie rods
RST Dana
OH
You may have replaced a bad tie rod, but nobody drives with a missing tie rod any farther than it takes to run into something!!!
Drewphil
