1997 Suburban 454 ECM Swap Help
Alex_M
Hey all! I purchased a buddies 97 Suburban K2500 7.4l. He had issues with it the four years or so he owned it. I'll say up front, my question is - what is required to swap a reman ecm?
History is as follows, for those interested and for a differential diagnosis if anyone has one. Buddy bought the thing and he had issues with an intermittent miss. Fairly regular (cutting in and out) above 3500-4000 rpm irregardless of load. Also happens at sustained ~2500rpm. Seems to be irregardless of load - it does it in neutral or driving about the same. Buddy tried plugs, wires, and cap/rotor. That didn't work so he figured it was a fuel issue. He replaced injectors, fuel pressure regulator, fuel filter, and fuel pump (twice?). He also replaced O2 sensors and crank position sensor at some point throughout all this. I felt it was more of an ignition issue as harshly as it would cut out, and the tachometer would dive when it happened. I replaced the coil and ignition module, no change. Also a consistent issue on hot restart with missing/poor running for the first 30-45 seconds. Changed the distributor and also no change.
Since I've had it the only code it has had is a Bank 2 lean code, but there is an exhaust leak on that side that I believe is causing that - I've not gotten the gaskets I ordered in yet to fix. Also just a note, AC isn't working and yes, all fuses have been checked.
At this point I am thinking it's an ECM issue, so today I pull the ECM to crack it open and just see if I can tell any obvious issues. No bad resistors or capacitors that I can see. No burnt spots on the board. One of the connectors where it connects to the board looks to be cracking but the other side is solid where it connects. A couple of the chips seem a bit discolored to me. I'll post pictures below. I clean up the original thermal pads and reapply new thermal compound to all the chips and mosfets that use the case for heat dissipation. Close it back up, throw it back in, truck won't start. No fuel pump. I jump the relay manually and the pump runs. Truck fires up, missing and throwing white smoke. Interesting note, the AC is now working, but the truck is running very poorly and I now have a new code - P1345 Camshaft to Crankshaft Position Correlation Fault. At this point I feel fairly confident in the ECM diagnosis, feeling the issue is too consistent for a wiring problem, and not knowing of anything else it might be. However, if you have another idea I am all ears.
So that leads me back to my original question - what is requried to swap in a reman ecm? They say they have to be programmed - is that something the dealer has to do or can I do a relearn procedure at home?
Thanks!
Alex
strutaeng
Dallas, Texas
Just get the Passlock security system disabled on the replacement ECU and it should fire up. Obviously things like gear ratio and things like that need to be programmed correctly.
If you get the ECU programmed, you can provide the VIN, but it doesn't have to match to run.
This is all true on the 0411 style ECUs, but I believe it the same on the "black box" types as well.
I believe the 1996 ECUs are the ones that cannot be programmed for some reason? But 1997 should be. Maybe check in the @BlackBearPerf ? They are a member here.
Marky Dissod
Provide
pcmperformance.com
with your VIN, and they'll sell you a new PLUG & PLAY 4plug black box pcm.
That said, my concern is that you have electrical problems which a new pcm may not solve.
In fact the electrical problems could eventually damage the new pcm.
Alex_M
Alex_M
Provide
pcmperformance.com
Agreed. The plan will be to get it running again and then do as much as possible to check for other issues throughout the system.
There have been a lot of cooks in this kitchen, which I knew going in, so I've got a fair amount of work ahead of me to bring it back to solid and reliable.
strutaeng
Dallas, Texas
I would say you need to perform more diagnostics before condemning the ECU. It's really rare to have an ECU fail, especially intermittently.
Don't rule out new parts because they were replaced. A lot of new aftermarket parts are prone to be bad out of the box.
It sounds like you have multiple issues going on. Start with fuel pressure test. Hard starts are usually a fpr or injector leaking after shut off, leading to flooding a cylinder when you try to restart. I don't believe the 7.4 Vortec had a FPR under the plenum though.
Lean on one bank only is something probably unrelated, but needs fixing as well.
a1parrothead
