07 LT 5.3L Sudden no start/crank
J-Herkel
J-Herkel
It's not comms with the BCM, it's just the ignition/key start signal. 12V.
and the yellow wire is the starter relay trigger signal.. The BCM is in the middle.
Here's all I can come up with..
Ignition switch "START" -> 12V to BCM (PINK J1-14) [no power? bad ignition switch]
BCM -> 12V to Starter Motor Relay (YELLOW J4-21) [no power with GOOD ignition switch? maybe bad BCM]
Again, that 8V seems low to me.. It may not solve the problem, but I feel like you're skipping a step if you don't test those wires..
(Considering your lights all light up fine, no codes, jumping starter relay socket works, fuses good, new battery etc.)
Or find someone with a scanner that shows if the key is in the start position. (to rule out the ignition switch)
Thank you. I have a friend coming over tomorrow with an advanced scanner to see if it comes up with anything. I'll keep you updated and highly appreciate your help!
rockola1971
Indiana (formerly IL)
Scanner will be practically useless for this failure other than to see input and output state of BCM and PCM. Need to ohm that ground terminal in the relay socket to chassis ground to see if it is electrically connected and rule out a busted wire.
mikez71
Good luck, fingers crossed! Scanner should be able to tell you if the ignition if ECM/BCM are receiving the start signal.
Should be able to rule something out I'm sure..
rockola1971
Dont we already know that is happening since OP is getting 12v at the relay coil when key is turned to engine crank? No way for that to get there without PCM and BCM being happy.
mikez71
Initially I thought he was measuring one terminal that went from 12V to 8V back to 12V.
Now I see he has one constant 12V, and the other goes from 8V to 12V.
bad ground doesn't explain the 8V, which should normally be 0V I thought?
Ohming the coil ground is solid advice. It looks like that ground isn't really shared with anything but the rear washer.
(even a functioning rear washer doesn't mean the starter relay coil ground is good, possible broken wire as you both mention)
Ground Zone #5, Not sure where it's located exactly, somewhere on left front side of motor..
rockola1971
Im not really concerned with the 8v right now since it didnt happen when the key was in crank position. The 12v according to OP was there in crank position so thats all the relay coil needs for the hot side. Now im concerned about the ground side not being there which would explain his symptom of no crank. Wire could have gotten bit by a field mouse, pinched by something, damaged during a past repair or ?????? OP Jumping the contact side of the relay and engine cranks proves that side of it is all good. So he has a control side problem and it appears the 12v side of that relay coil is all good. I bet if he sticks a meter lead in the ground side socket and measure resistance to chassis ground that he will see way more than the 2 ohms or less that I would expect to be there. Those fuse boxes are pretty famous for corrosion underneath right where the wires come up to the fuse and relay socket terminals from underneath. The green crusties have been spotted there many times.
J-Herkel
J-Herkel
I took the entire Fuse box out yesterday, took it apart, removed all fuses and relays, removed the inside board and it was all clean. No corrosion. I will ohm the ground later when I get home. I'm praying it's something simple like a bad ignition switch but at this point, I have no clue anymore. The hardest part for me is the lack of symptoms. No crank/start and that's it. No thrown codes (to a regular scanner), no loss of power, good battery, good fuses, starter runs when jumped. I don't understand either why the relay is getting the 12v signal, along with the constant and you can jump it off its own ground terminal, yet it's not turning over the starter. When the starter is jumped via the relay, the engine turns over but doesn't fire. It just cranks. I'm assuming because I'm bypassing the other functions needed for it to operate like fuel and spark. It's hard for me to see a failed BCM or ECM without prior failure symptoms before ultimate failure. Who knows at this point. Hopefully this scanner later and help pin point something!
tc8510
TX
Have you checked all your grounding wires? I had this same issue. It came down to my grounding wire that goes from the firewall to the top of the engine block. It was hanging on by a thread down by the block.
TexasBob
I am having what sounds like the same problem on an '03 1500 engine Yukon now. I fixed that particular grounding wire a few years ago. It broke because GM didn't leave any slack in it.
J-Herkel
J-Herkel
I'll check it when I get home. I know what you're talking about. The firewall side is good. Haven't checked the engine side.
J-Herkel
J-Herkel
Alright so after some more diagnosis this evening, I had my buddy hook up his $7000 scanner and scanned the entire vehicle. The Theft Module is good. The BCM was good. The ignition switch is reading key postion correctly, the signal is being sent when the key is turned to the crank position. The ECM was good but detected a fault in the Start Relay Circuit (P0615). So we used a schematic and traced the wires to the connectors below the Fuse box that the Fuse box itself plugs into. We tested the relay terminals. 30 is good (12v). 87 is good (12v). 86 is good. 85 (ground) is not good. No reading. We took the fuse box off and out and tested the terminals on the plugs below. The power (+) side to the relay is all reading. The ground (-) is also reading fine. Next I pulled apart the fuse box and we tested the contacts on each side of the board. The power side has continuity. The ground terminals do not. We touched the relay ground terminal to every terminal in that bank that it leads to and no continuity. As weird as it sounds, it seems like the fuse box relay circuit went bad on the fuse box circuit board. I'm assuming I can put it all back together, use a thin wire and stick it in the ground side of the relay, ground it to the frame, insert the relay and see if it cranks. Thoughts? Ideas? I'm not an auto mechanic but I'm doing my best here.. I did see a little bubble on the board. Maybe it has nothing to do with it. Idk. I'll attach a picture.
Geotrash
Dave
Richmond, VA
Nice sleuthing! We've seen corrosion take out the circuits on the bottom of the fuse block in the engine compartment and cause weird issues. So yes, you're likely on the right track.
rockola1971
That sure is odd. That circuit board doesnt appear to be a multilayer circuit board. So just the traces on the top there in the pic and likely ones on the underside as well. Not alot to go wrong there and if it does it usually shows a physical defect. Id have to so better pic and the ground terminals marked to see if your "bubble" is the culprit and it very well could be. The bubble can be bridged with jumpers on the trace of the board. Ive had to repair many obsolete boards over the years when I worked in the private industrial field. Running your own ground at the relay socket (top or bottom) is fine as long the correct wire gauge is ran AND the proper automotive rated wire with the correct temp rating is used. Remember it it always hot as hell under the hood of a vehicle.
j91z28d1
you might not think you're a mechanic but this is better trouble shooting than most mechanics can do these days.
definitely add a ground to the relay and see if it all works, if so you might consider picking up a new fuse box at a junk yard. Just incase it starts having issues to other relays long term.
J-Herkel
J-Herkel
Once I get it all back together I'll try a jumper ground wire. Appreciate the compliment.
J-Herkel
J-Herkel
So I went back again this morning and did some continuity tests from the top of the board, starter relay terminals, to the bottom of the board terminals that plug into the banks of wires that run to the other components. Relay terminal 87 (F1)(to 40amp starter fuse) has continuity and is good. Relay terminal 86 (C5)(to ECM starter relay) has continuity and is good. Relay terminal 30 (A)(hot at all times/main power) has continuity and 12v and is good). Relay terminal 85 (N5)(ground to engine block) has no continuity to the N5 terminal on the back of the board. I ohm tested the wire it plugs into under the fuse box on the vehicle, and it tested good for a ground. Since the computer is sending the crank signal, it's reading the key in the crank position, no theft control module is active, the starter jumped off the relay and worked, my only thought that it can be is the ground (N5) on the board. Without the ground it won't activate the relay. And I wasn't getting any clicking in the relay when we were trying to crank it yesterday. I'm attaching more pics of the "bubble". By the way, I also checked the N5 (ground) circuit which also leads to the ground terminal on the "run/crank" relay and I had continuity there so it does seem like there is a broken connection between the N5 plug on the bottom and the ground (85) terminal for the starter relay.
J-Herkel
J-Herkel
Since the starter relay and the run/crank relay share the same N5 ground on the bottom of the board and the run/crank N5 seems to have continuity and the starter doesn't, I added a jumper wire. I'm going to see if it works. If so, this will be my permanent fix. This jumper is just a ground wire.
Jumpshot12
