Will Z71 avalanche rear fender flares fit on a Tahoe?
Brizzzy
Does anyone know if the rear flares on a 2011 avalanche would fit on a 2011 Tahoe? Obviously you would need to cut them to fit the Tahoe since there is a piece on the door and the bumper is separate, but could they fit otherwise? They look to follow the same body lines and I think they look very similar.
Long story short, I’m looking for Z71 flares for my LT Tahoe, but can’t find any. I found a full set of flares for a Z71 avalanche that are the same color as my Tahoe and I’m wondering if I should pull the trigger. They’re listed at $400 for the whole set, so it could be a decent loss if they don’t fit. Is it worth the risk?
I’ve attached some pictures I found of the avalanche and the Tahoe for comparison.
Let me know what you think or if anyone has any info or experience with this, thanks!
No, the Tahoe is shorter and the flare cuts into the door where it doesn't on the one made for your longer Avy.
These are the part numbers I see for the rear for your truck: 15944821 for the Driver's Side and 15944822 for the passenger side.
GMPartsGiant shows the driver's side still available. If you do an exhaustive search, even trying Amazon and putting out a search on Ebay, I'm sure you'll turn up the other in time.
mikez71
There's some aftermarket flares that look very similar.. Only difference I don't like is the rear bumper section is integrated instead of a seperate piece..
Brizzzy
Brizzzy
Thanks for the heads up. I was mostly going for a used set so I could avoid having them painted, but it looks like that might be difficult to do
Brizzzy
Brizzzy
Thank you!
Raptor Tahoe
Have you looked at Bushwacker flares? They offer a variety of street and rivet flares. I am extremely happy with mine and they were easy to paint and install.
I went with the bolt-on heavy duty look and am very pleased…
Good luck with your project!
Charlie21ny
