Writefast
2007 Yukon SLT 5.3. So after removing the MAF and cleaning MAF and throttle body I took her for a drive. Seemed a bit smoother than normal which was good. But about five min in the cluster threw the Service Battery Charging System Soon warning. I looked at the gauge at it was hovering just about 1/2 way between 9 and fourteen and dropping slowly. It’s blazing hot out so the ac was blasting and I was running full lights. Killed the lights and ac and gauge walked back up to 14 and then climbed a bit higher. Came to a stop in traffic so I decided to test. Turned in ac, no immediate change. Turned on lights and the gauge started dropping again. So I killed them all again. Traffic starts moving again so I test again. Ac, no problem. Lights, and the gauge drops but more slowly. Pull into a parking lot and open the hood. Nothing looks amiss. Coolant is full, all connections that I might have bumped or broken look good. I kill the motor (I have a portable jumper), wait five min and it fires up immediately no problem. Drive her back home and it’s pretty much the same except the coolant warning is gone. What in the actual FortNine is going on here? There’s no weird flickering as far as I can tell. Alt is only 2-3 years old. Battery less than a year.
There is one other weird thing. After reinstalling the MAF et al, when I fired her up I reached in and turned the key and released as normal, she did not fire up immediately but she did, without me keeping the key turned, continue to turn over by herself as I stood outside the vehicle. It was so weird it took a second to register. lol. Did that for maybe 10 seconds if that long and then fired up strong as normal.
I’m currently lost. lol. What did I break?
Writefast
Writefast
One more thing. I let it sit and idle in the driveway after the drive with full lights and AC. Gauge stayed a hair above 14 and did not move.
Writefast
Writefast
Fired her up again in the driveway. Ac, full lights, and fans kicked on at the same time and voltage drop. Turn lights and ac off and return to normal. No fans, ac and lights are tolerated. My meter says that charge is hovering between 13.3 and 14.8 when idling.
tom3
Serpentine belt been replaced recently? Maybe not turning the alternator fully when under big load. I'd get the alternator tested if any local place can do it. Can't rely on most replacement parts these days seems like.
Writefast
Writefast
About 4 months ago on the belt. And having the alt tested is next. Just weird that this all started after fuckingbaround with the MAF and headlights.
j91z28d1
with a good scanner you can read the current draw reading from the current meter. that would give you an idea if your headlights are pulling some kinda crazy current. these ecm's vary voltage all around it's not the most reliable gauge of load anymore.
I doubt the maf effects the alt, even tho anything seems possible.
alt is pretty cheap, you could take this as a good reason to upgrade to the newer style 220amp alt. you can find low mileage oem ones on ebay for 150$ ish last I looked. the part numbers and info is around this site somewhere. but basically a direct bolt on. that would at least rule out if the atl is failing.
Writefast
Writefast
I’ll break mine out and see if it can read that. Didn’t think about using it. Thanks!
Writefast
Writefast
NOPE. THIS WAS NOT THE SOLUTION. DISREGARD. DAMN THING IS STILL NOT CHARGING CORRECTLY.
AND THE SOLUTION WAS:
Bad alternator. More to the point a bad voltage regulator on the alternator. Now time to go break something else. lol.
mikez71
220 amp is only $160 for acdelco at rockauto. (use 2019-2021 silverado 1500 5.3) I was going to buy one to replace my used ebay unit because datalogs show my voltage continuously fluctuating .1V, but apparently that is normal with computer controlled alternators... a few bigger less frequent drops in voltage show up on my logs as well.
Writefast
Writefast
And failed. New alternator is reporting that it is failing to whatever device it is that O’reillys uses to talk to it.
So:
Motor cranks strong.
Sitting in the driveway in park I can crank everything thing up. Lights, ac, radio. Needle barely moves.
When the fans kick in interior lights dim significantly, needle moves a bit, but near 14 is maintained.
Apply brake, no change.
Put it in drive and the needle starts to dip significantly. Bottoms out at about halfway between 9-14. Seems to want to stay there but I’ve yet to go longer than five minutes in this state.
Kill lights, negligible results but some positive movement.
Kill everything else and the needle begins to very slowly climb back up.
Putting it back in park makes no difference.
Running rpm, while in park, needle climbs back up to 14 within 3 min or so. That’s with everything off.
Could a failing battery current sensor be causing this?
Writefast
Writefast
Yes. New serp. New battery. And now a new alt. I think I’m returning it tomorrow. Should have today but I’m a stupid monkey.
j91z28d1
kinda sucks to keep buying things, but a cheap DC amp clamp would at least tell you what the alt is putting out. you could compare that to the scanner reading, or get an idea of what kinda load all that is pulling? cooling fans are a lot but also a old failing cooling fan motor starts drawing a lot more amps as it burns up.
its so hard to guess over the net but I do wonder if you're just putting say a 100amp load on a alt that can't keep up with that at idle. sounds like if the rpms are higher, it can hold the voltage up?
your putting the cart before the horse
start at the battery and start testing battery cables and grounds.
your battery is the power source..... it needs a good solid connection for everything to power up.
use a meter.....
it sounds like you have a poor ground somewhere, the more draw you put on the system the less it can handle it.
ohm test grounds to battery negative post.
since it is a 07 unbolt the "mega-fuse" on the firewall and clean it up and reinstall.
Your computer is telling you now that something is wrong with the charging system. After checking/replacing the cables, the alternator probably cannot perform under load to the satisfaction of the computer program. You can unplug the current sensor which will run the alternator at full output.
Use a bi-directional scan tool to check the state of charge of the battery. Or wait till morning after she's been sitting all night and check the voltage against the ambient temperature outside to determine what it is. If it is below 65%, it's time for a new battery.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
I was going to say it sounds like a ground cable issue. You should check the ground point on the engine block on the passenger side and there is one on the front end of the passenger frame rail. You will need to take the bumper cover off to get to it. Many times these get corroded inside and become a resistive but they look “fine”.
Many of us have experienced strange electrical issues that were bad ground circuits.
Foggy
KS
ACDELCO 13536552
This is what I looked up on RA. 220 amp for 2020
Is this a direct fit (2014 denali 6.2) ?????
Because that is a smokin deal for a high amp alternator
1948Buickroadie
