Harmonic Balancer install?
Eldiablo
Well guys, when I took off the harmonic balancer I noticed there was no key. I failed to mark how it came off. I asked a couple techs over here and they told me just to put it on. I dont buy that. So now what do I do? I read somewhere here put it at top dead center and align a pointer of the balancer at 12:00 and that should be it. What is the real deal boys???
firsthere
How does one keep the crank from rotating while torquing the balancer bolt. From what I have read the depth from the tip of the crank to the balancer face should be checked which would involve removing the bolt again?? Are two bolts needed for this procedure as they are one use only?
I had to sent my balancer back with the engine core as I could not get the damn thing off even with heat from a torch.
Tonyv__
Bucks county PA
Impact gun set to Max ugga Duggas
Scottydoggs
NJ
most will use a pry bar on the flex plate teeth to the block to keep the engine from rotating. or the air gun deal does work. the crank bolts is supposed to be tty one use only why the installer is nice cause its a 18 dollar bolt.
AllyNJ
