Determining Actual Mileage
S33k3r
Dallas, Texas
My new-to-me Escalade has a cluster with the incorrect mileage: Carfax shows 25k more miles (this, in itself, is not an issue) than the cluster does. I have been told there is a module/the ECM has the actual mileage stored somewhere... Does anyone know where this might be found? I just want to get the mileage right, and it should be higher than listed.
not on that gen. it's in the cluster, if someone replaced the cluster that would explain it. Legally any discrepancy is supposed to be on a sticker in either the drivers door jam or inside of glove box stating the actual mileage is different.
In any case a speedo shop or anyone that does cluster repair can correct it so it shows correct mileage.
only the 2015+ have it stored in the bcm and cluster.
on a side note if you take it anywhere for work and they report to carfax and the mileage pops up short thats going to trigger a alert for mileage discrepancy
S33k3r
S33k3r
Dallas, Texas
Thanks for the warning. I'm just going to get the estimated miles from Carfax and get the cluster updated. It was just a bit concerning was all.
S33k3r
S33k3r
Dallas, Texas
The cluster itself states 200554 miles or so. So I am going to look at the last number reported to Carfax, assume the cluster work reset to 200,000, and then add on the mileage from 200,000 to the Carfax number. The Escalade is already exempt from reporting mileage, but I'd still like to be as close as possible.
MrBalll
West Texas
When I got an Escalade cluster for my Tahoe from a junkyard I sent it to an online shop and they changed the mileage and hours on the Escalade cluster to match mine. Was very cheap but I guess whoever got your new cluster said no thanks and just installed it and drove it.
drdave81
Waterford, MI
You said the carfax was showing estimated mileage? You're going to update mileage based on an estimated number? I'm a bit confused by that comment.
Any modification YOU make to the odometer now, could potentially put YOU liable for odometer fraud. I'd just leave it alone, if you don't know what the actual mileage is.
Wouldn't really matter, unless he was trying to misrepresent actual mileage--but it's mileage exempt anyway.
drdave81
Waterford, MI
Yep, according to NHTSA......
"If the odometer mileage is incorrect, the law requires a statement to that effect to be furnished on the title to the buyer. However, a vehicle is exempt from the written disclosure requirements if it’s 20 years old or older, or a model year 2010 vehicle or older."
Odd wording though "20 years old or older, or 2010 vehicle or older" so which is it? lol
Bureaucratic double speak.
S33k3r
S33k3r
Dallas, Texas
Carfax is showing **Reported** mileage, not estimated. And, as @Tonyrodz said, mileage is exempt in Texas. I did not have to report mileage when I retitled it into my name.
look on craigslist, facebook there are people all over that do speedometer repair especially on gm's anyone of them can rewrite the mileage, there are at least 4 of them that do it here in my town locally as side gigs.
S33k3r
S33k3r
Dallas, Texas
I actually have a guy that will do it. The point of this thread was to determine if mileage was stored in the ECU or similar, so I could have the exact mileage programmed. Alas, it is not. But thanks!
RichShips
