Looking for 26 inch tire recommendations
AZXL26S
I have a 21 Yukon XL that I have 26 inch wheels on. I bought a brand new set of Lionhart tires and I'm not happy with them at all. The truck is not a daily driver and when I travel I put the stock 17s back on. I had 1 tire get warped on the sidewall and almost blew and now I have another with uneven wear on the inside with exposed wires. I would like to get any recommendations on other brands that are less problematic. Tire size is 295/30/26. Thanks in advance and yes I regularly get the wheels balanced so that would not be an issue.
Danielmcc
I'm on my second set of Lexani LX-Thirty 305/30ZR26 right now. Other than being a softer rubber than an offroad tire and living in a city with a ton of road debris so I have probably picked up 6 nails in 25k miles, I actually have zero complaints about them. Both sets have balanced out well, ride smooth, and grip great in dry or rain. Also there is absolutely zero rubbing even at full lock even on stock ride height. My first set was still at 50% tread but one tire picked up a large chunk of metal and couldn't be repaired, and since they are literally $160 each on Amazon I just bought 4 new ones. The 305s are just a much better size than the 295s on our trucks because of how big Tahoes and Yukons are, that extra sidewall height and tread width really make a big difference in look and ride quality.
2024 White Tahoe
Does adding non-OEM size tires affect the ABS, automatic emergency braking or the stability control systems?
scottd
