service suspension message (diag?)
ReaperHWK
Recently I have the service suspension message pop up on my dash. It is not always on but intermittent.
The truck is a 2015 Tahoe LTZ with the magnetic ride suspension, car is 100% stock with 150k miles.
For the last year or so when I start the car, I hear a "gurgling" type noise from the rear that lasts for 5-10 seconds and goes away, wonder if that is related? That noise always occurs on startup.
What are common things I should check? Also, my scanner won't read these suspension codes, anyone have a recommendation for a scanner that works to read the suspension code?
Thanks.
the noise is likely the airpump, it should sound like a airpump, such as a smll one you would use to air up a flat tire. the rear shocks have bladders and should feel like a inflated rubber ball, you should be able to squeeze the shocks by hand and they should feel firm, but not rock hard or deflated.
the code will likely tell you exactly what the problem is, just need a tool to read it.
I haven't used this one but it's supposedly a good one and they recently dropped the price a bit
ReaperHWK
ReaperHWK
Thanks for all this info, it 100% sounds like a faulty airpump noise to me. I'll go under and check the bladders. I didn't know there was an air bladder I just thought the shocks were magnetic ride is all......
Geez that scanner is expensive for what I need; I'll see what Amazon has as well if I can't find an obvious visual problem.......
Ya with these new trucks the cost for self diagnostics tools has gone up, hard to find a good one that is sub $500 and can do advanced analysis
k_arnold72
I had the same intermittent service suspension message. I took it back to the dealership service center and had them plug into the obd port and give me a print out that pointed me to the location of the issue. In my case it was not a leaky shock, but an open circuit. So I cleaned up the two connectors on that shock, added anti oxidation compound, and the notification has not been back since.
So I would second getting it diagnosed by the proper code reader before possibly misdiagnosing
ReaperHWK
ReaperHWK
You recall how much they charged for the diag?
Buy a quality bi-directional scanner, and don't look back. I guarantee you that the scanner will pay for itself many times over what what you will save in diagnostic expenses over the life of your truck. I know that my scanner has paid for itself multiples times over in the 5 years that I've had it.
k_arnold72
No charge, but I'm assuming that was because it was the same dealer I purchased from.
I can't imagine it would cost much, it plugged in and printed out the history of faults in 5 minutes.
ReaperHWK
ReaperHWK
I found this on some youtube channel and on Amazon, supposed to read all the codes (including suspension module) on GM trucks only. Maybe I'll give this one a try, it's $110. The only drawback is it only works on GM trucks.
ReaperHWK
ReaperHWK
the reviews are not promising lol
Yeah I changed my mind. I actually got this one on sale($489 with prime lighting deal) Also they had no interest for 12 months so I’ll just pay $44 a month for it. Looks like one model up from the one you posted except it’s corded vice Bluetooth. I rather have the more features than the Bluetooth for the same price was my logic.
ReaperHWK
ReaperHWK
Well I got the fancy scanner and it won’t com with the suspension controller like it’s not even there. Only code was from the BCM saying it can’t comm with the suspension controller so I knew it’s either a wiring issue or the controller is totally dead. So I checked fuses for it and went under the car. I think I found the problem in case this helps someone else. The main wiring harness for the co troller rubbed on a cross brace and it cut through several wires, one of them the main power.
6point2lovelifers
