U-Haul Trailer Towing Questions
BlaineBug
Clown World
I will be towing a dual axle U-Haul trailer loaded with stuff about 1,200 miles in a week in a half. My questions include;
1. What do I air up my tow vehicle's tires to? Maximum inflation listed on sidewall?
2. What do I air the trailer tires up to? Maximum inflation listed on sidewall?
3. Do I have to stop at weigh stations?
Thanks!
15burban
Wisconsin
For the tow vehicle you could bump up the psi a few but probably isn't needed. All depends on how much weight the trailer and contents inside are. Tongue weight should be between 10-15% if loaded evenly so at 1000 lbs (just a random easy number) only roughly 100-150 lbs will be on the tongue or the tow vehicle itself.
Going by your door sticker (if you still have somewhat of the same tires that came from the factory) the psi listed should cover the axle weight ratings. So as long as you don't go over that the psi listed should be fine.
jamoody
If this is your first time towing here are a few extra points to consider:
* Put the tow vehicle into Tow/Haul mode
* Don't use cruise control
* Don't exceed the maximum speed rated by the trailer tires as indicated on the sidewall (probably much lower than the tow vehicle tires) see https://simpletire.com/learn/tire-buying-guides/tire-speed-rating to decode the rating
* It's extra important to keep the trailer tires at specified pressure (they are a different design than vehicle tires and probably at 60 PSI or higher, at low pressure they are susceptible to failure from excessive heat buildup due to sidewall flexing)
* Stick to the speed limit (or lower based on trailer tire rating) to reduce braking distance and reduce trailer sway
* Be extra cautious of braking distance going down hill and on wet pavement
* Use the truck parking area in rest stops
* Park to avoid having to backup
* Watch for left lane exclusions for combination vehicles on highways
* Know your trailer height and watch for low clearance (wires, branches, bridges)
B
BlaineBug
Clown World
Questions - Now that both tow vehicle and trailer are loaded, should tire pressure be adjusted? I checked the tire pressure on the trailer and it is now higher than the "Maximum" listed on the sidewall. Also how do I compensate for temperature? Say, I leave here 75 degrees Fahrenheit, and the temperature at the destination is 98 degrees Fahrenheit (realistic comparison!)
Also, for the tow vehicle, do I inflate tires to maximum PSI as tow vehicle is both loaded with a trailer attached as well?
MobileHomie
Set the tire pressure cold, this means ambient for where you are, before driving. Do not adjust or let tire pressure out when tires are hot, this means on a short stop. Heat will increase the pressure, do not let any out. The higher ambient temp at your destination is not an issue.
It is not a bad idea to stop after a few miles and put your hand on the tires and center hubs, they will be warm. If hub is too hot to touch, there is a problem.
Those trailers don't put more than a couple hundred pounds on the bumper, shouldn't be an issue for your vehicle.
B
BlaineBug
Clown World
The travel was a success. I never reported back however there were no issues along the 1,200 mile journey. Averaged about 12-13 mpg. It was heavy, acceleration was lacking, however once cruising I experienced no issues to report, no bouncing, sway, etcetera. Braking was also acceptable. I'm late to reply as I returned the trailer nearly 3 weeks ago.
Bigburb3500
You must have had that trailer loaded with stuff to squat the back of your Yukon! Glad your trip was safe!
B
BlaineBug
Clown World
It was completely full, front to rear, top to bottom. I eagerly unloaded it and forgot to take a picture of how full it was. Also, the Yukon was also loaded as well, contributing to the squat.
dps01
Senior Member
Navy Supporting Member
N. TEXAS
About to rent the same trailer to haul from OH to TX in a 2003 Z71. Going to take it nice and easy. She is @ ~240K on original engine and tranny. Hauled U-Haul auto transport a couple of times in the past, but the Tahoe was a bit newer then.
When you load the trailer, try and put the heavier items over the axles and not up front which will weigh down the truck. That's what I do anyway when I rent those 12 footers.
B
BlaineBug
Clown World
On my journey I saw people towing these double axle U-Haul trailers with much, much smaller vehicles. So much that some of these trailers were tilting far forward just to be able to line up with their trailer hitches. I think I saw a Subaru pulling one at a Buckeys. With anything less than the V8 as bad as acceleration was, I can't imagine towing one with a 4 cylinder. Unless of course they're empty, but then why rent such a large trailer if you weren't going to load it?
St. Louis
I rented one May 2023 to move my son from college to his new place. It wasn't loaded full, but had quite a lot of stuff in it. Pulled fine and didn't really notice it was there, but that was with the 6.2l XL
Drewphil
