Snapped Headlight housing clips
iboughtatahoe23
On my 2014 I changed the headlight bulbs and I had to give the housing a good yank to get the clips to break free. I didn’t really see any other option. I got the bulbs changed but the clips to one of the housings won’t snap back into place. It looks like the clips anre still on the housing but now Now my driver side housing wobbles a bit.
Hoping it doesn’t affect the light path or short anything out
On my 2014 I changed the headlight bulbs and I had to give the housing a good yank to get the clips to break free. I didn’t really see any other option. I got the bulbs changed but the clips to one of the housings broke clean off and Now my driver side housing wobbles a bit.
did you take pictures? of where it broke and the broken piece?
iboughtatahoe23
iboughtatahoe23
if you still have them try a heat gun and see if you can weld them back on, it's just plastic some is more resilent to being heated up than others, might be worth a try.
or if there is enough width, try drilling out both side and use a dowel or metal sleeve with either heat or epoxy
gorilla glue has worked for me in the past you just have to let it sit overnight, it expands so use sparingly and don't have it near anything it can get glued to
iboughtatahoe23
iboughtatahoe23
Yea I was gonna try something like that. The whole piece didn’t snap off. It just snapped the part that actually secretes the clip. Like now it just goes in the bracket but doesn’t stay.
GMT800 2005 Tahoe Z71
Navy Supporting Member
If it is wobbling, it is affecting the light path. Moving a 1/4" at the light housing is moving feet a few yards out.
iboughtatahoe23
iboughtatahoe23
Try Q-Bond for the repair.
Maybe I didn’t explain myself enough
The clips are still there they simply just don’t click into place like they used to. I push the housing in like shown in the video and than it just sags an 1/8 inch. If I glue it in I’ll never get it out without breaking it. I can’t really think of a solution other than new housing.
I’ll try to remember to take some new pictures when I get home.
iboughtatahoe23
iboughtatahoe23
Like the two plastic pins are still on the housing but they won’t snap into place where circled
Those are just locating pins. Something else is not attaching as it should to hold assembly in place.
iboughtatahoe23
iboughtatahoe23
Looks like I’ll be ordering two new housings bc of one little issue. How dumb haha.
All attaching areas should be inspected. The attaching components on the housing and where they attach at in the hole where the housing sets. You could have an attaching piece that is fine but the housing could be damaged where the attaching component attaches at the housing. Or something is damaged where the attaching component grabs at the vehicle.
What I am trying to say is, you could install 10 new housings and never fix the problem.
Yizzo88
