Steamrash
Also mine is NOT a z71 and had to have the ends cut off to get my bumper on (I didn't do the work just saw the aftermath)
Yes I noticed that after the fact... They all have those ends. The cutting part wasn't as bad plus I got some metal work XP out of it... it was the demoralization after opening it all up and seeing something completely different. I'm past all that now since wiring is the new nightmare. I wanted to be cool and send in the switches from the passenger side instead of the stock wire grommet under the steering. Now I gotta take apart the AC vents under the glove box to see what I'm dealing with.
dps01
Senior Member
Navy Supporting Member
N. TEXAS
I don’t know about that sob story…
Steamrash
Still false advertising on the main page... No cutting, grinding, welding? All the rookies like me who think it's just a couple of screws are falling for it. Either way ... Almost done putting it together anyway.
strutaeng
Dallas, Texas
That's what we're here for my friend. Love this forum, and I like to contribute useful info when I can--and non useful bs:p
Do it again Tony.
Now my 06 Suburban did the same. AC tensioner seized and snapped the belt. DejaBoo!
Steamrash
Nice progress.
Looking forward to finished product.
I really like their stuff.
Want the rear bumper w/ tire carrier.
Always hated mine underneath.
Here's a night photo for now... I wrapped up an hour ago. Finished at 6 but as you could see from my previous pics I make a ton of mess everywhere.
Steamrash
Nice progress.
You can put a water reservoir underneath instead, and you can fill it from the top without removing and putting back. I totally agree. Tire on the swing plus maybe a trash bag on top (or not) but so much more room for stuff without making the car any wider. I would've loved that too but I have a bike rack.
Do it again Tony.
I think this is a fairly common issue because the tensioner is mounted so low on the engine. I think it's prone to getting wet a lot and getting exposed to debris, and over time it just gives up the ghost. Did you replace it already?
It's been a few years since I replaced mine, so I'm expecting mine to seize up soon too lol.
strutaeng
Dallas, Texas
Yeah, I think you are right. The tensioner sits low in the engine and I would imagine it gets a lot of water and debris.
I didn't replace it yet. Will order new parts today from RockAuto.
This is the engine I just overhauled and had replaced the belt because it had some cracks on the ribs. The lesson learned is: replace the tensioner along with the belt.
Scottydoggs
NJ
from personal experience, if the belt snaps and the the tensioner pulley breaks. your ac compressor is on borrowed time.
so if the belt breaks again in a weeks time. just replace the compressor. or you will be buying another belt, then another belt and so on and so on lol fml type of deal. i went 3 belts deep and a tensioner lol
redhat9
My OE z71 running boards were starting to oxidize and peel paint in certain spots, not to mention the amount of rock chips on the front.
Pulled them off and ground down the corrosion with a fine 3” blue fiber wheel on my 12v mini polisher.
I’m going for looks good 10ft away, not a show truck. I cleaned them meticulously with degrease and acetone, then primed them with self etching primer. Tried some satin black but wasn’t a fan of seen all the imperfections… plus it just didn’t lay down right.
Remembered I had a few cans of bed liner spray in the cabinet. Tried that and was pleased with the appearance.
Sam Harris
Finally took some time to clean her up a bit. I hate having a dirty vehicle, but just don’t have much time these days..
redhat9
While I was doing my running boards, my passenger side Z71 cladding has always hung low. Took it off to find the cladding bracket missing some of the 1/4 rivets. Also found most of the 1/4” rivets holding the top of the running board mounts to the rockers gone.
Spent the after noon re-riveting everything. Man these running boards are solid as all get out now. Super pleased.
Also super happy with how the truck is holding up. 20 years and a NY truck, rockers are mint. I will continue my liberal oil undercoating and washing routine.
dps01
Senior Member
N. TEXAS
Huge fan of rattle-can bed liner for hiding imperfections. Used on my Z71 running boards as you did as well as the rear appliqué’s… also did the rear bumper and the used a top coat / clear coat over it to match the body color…
strutaeng
Dallas, Texas
I took my 1999 Silverado for state inspection. The lady told me first year of inspection with no emissions check due to it being considered a "classic" 25 year old here. So just safety inspection and only $8 (vs. $30)
Yeah!!!
Korbin_A
