Maybe not all 6.2's have the bad lifter bore/ bearing wear issues
DontTaseMeBro
Read the TSB carefully first, your VIN is probably inside the window of suicidal 6.2L V8s.
Or, you could just go in there blind ...
I'd want to be able to smack anyone that tries to slow me down with a piece of paper that basically says I'm gonna get what I want or else.
Wonder how this affects those who got an engine replacement in 2023…
Smokin Denali
I don't know what the statistics are, but there are many 6.2 engines that will not see those problems (knock on wood) our 2022 has 18k, so far so good. If something does happen I will certainly be reporting it to the Forum.
My 2015 6.2L Yukon Denali was great for 30K miles. Then a valve spring broke at 30.ph in a turn, and knocked me down to 7mph.
Towed to Dealer Repaired in 4 days.
Ran great till 48K Mike's. Valve/lifter broke on me . Both sides replaced. 2 weeks!!
Runs hood at 79K now. Trading in cause its gonna happen again....
ranger0787
I called GM Directly at 800-462-8782 and told them what I found online about the "Customer Satisfaction Program N232413430 Oversized Lifter Bores" as mine seems to be an affected vehicle. My build date was 11/16/2023, gave them my VIN and they said my vehicle is not affected. Also asked about the rear suspension bolts not being properly heat treated (#N232415910) and they said that my vehicle was also not affected
  • N232413430 — Oversized Lifter Bores.pdf
Marky Dissod
I called GM Directly at 800-462-8782 and told them what I found online about the "Customer Satisfaction Program N232413430 Oversized Lifter Bores", as mine seems to be an affected vehicle.
Also asked about the rear suspension bolts not being properly heat treated (#N232415910),
and they said that my vehicle was also not affected.
Any way to confirm that the vehicle was one of the ones unaffected.
Not asking for me - asking so everyone else can get their own answers.
ranger0787
They never said how; but my vehicle wasn't listed as "Open" in their system and they did need my VIN. I explained to them that it should've said, "Vehicles manufactured prior to 00/00/0000 are not affected. But the bulletin is very vague.
ENTX
TSB doesn't seem to have the affected VIN ranges so I guess I'll have to call the GM as one of the previous posters did.
I'm at 13k miles now... It would probably die already had it been affected? :) or is it false hope?
P.S. Just chatted with GM customer support an after reviewing my VIN that are not seeing any recalls associated with it. I don't fully trust this because this was not an official recall, right? Just some kind of "Customer satisfaction program"...
tom3
They don't like recalls. Issue a TSB or program to fix it AFTER it fails.
Antonm
Antonm
All VIN’s within the year model range are affected, there is no “ good or bad” window, it basically says to fix it after it breaks.
vcode
That's not how I read it. It says only vehicles with an Open Vehicle History Screen are affected. It also says certain vehicles are affected, not all. Also read Engines used for replacement must be specially ordered by dealerships and allocated to specific VIN numbers. No way every 6.2L is involved. People have already called with their VIN and told they are not affected. You will get a letter from GM if you are.....
mp5pdw
I guess after reading this I should look at the Ford Expedition because they never fail? Haha
Antonm
Antonm
Gm doesn't know which vehicles do, and which vehicles don't, have a defective engine. This is a "fix it if symptoms appear" type TSB. They can't publish an "Affected Vins" listing, because they simply don't know which vehicles are affected, but the TSB covers everything they put the truck 6.2 in for all three badges (Chevrolet, GMC and Cadillac).
So there is a 100% chance that if you call GM and ask "is my VIN affected" they will say no unless you've already taken your truck in to get the engine replaced because its locked up beforehand.
Marky Dissod
In other words, if it ain't broke, GM won't fix it.
Is there a clever way to artificially induce the specific failure mode / symptoms intentionally? ... ?
Antonm
Antonm
Not that I can think of and you really wouldn’t want to do that anyway.
If your engine is good, leave it be. Changing out an engine involves taking a lot of other stuff apart.
Dealership techs get payed based on book time. So if the book says it takes 3 hrs to do a job, they get paid 3 hours of their hourly rate. If they rush through , do a half *** job, don’t bother to actually torque anything ( just use an impact driver on everything) and get that 3 hour job done in 1 hour, they still get paid for 3 hours. So if you can get four of those 3 hour book time jobs done in 1 hour each, congratulations you just got paid for 12 hours work and you only spend four hours doing it.
The dealership management knows this and often pays them less per hour because they know they’ll just rush through everything. Some dealers limit the techs to 12 hours pay per day, so those guys just leave a noon after they’ve rushed through 12 hours of book time work in the morning.
Long explanation saying you’d much rather have an engine that was installed on the assembly line with all the coorectly calibrated tools than one that was rush installed and had stuff bent out of the way instead of removing it by a dealer tech.
Flugzeugfuhrer
For our new $90K car, I decided to change the oil at 500 miles, then again at 3K miles and then again at 6k miles to get rid of any break-in metals before starting a regular oil change interval routine.
Because of all the issues the 6.2's in Tahoes, Yukons and Escalades seem to be having, I decided to send a sample of the oil that ran from 3K to 6k miles off to be analyzed. Figured if the engine was tearing itself apart, there would be evidence of it in a used oil analysis.
I'm hoping I got the one good 6.2 that managed to sneak its way out of the factory. I'll probably continue to do oil analysis every other, or maybe every third, oil change just to keep an eye on it, but so far it's not the kiss of death.
2020 6.2L Denali XL with oil changes every 7k-7.5k miles - heresy to some people here:) Over 100k miles, no issues, Blackstone analysis after every oil change and notes to keep doing what I'm doing.
TKOd Silverado
2024 Silverado 5,622 miles, engine let go, dealer is ordering a new engine.
Has the lifter/bearing issue been resolved in the replacement engines? I'm on the fence as to whether I want to take the chance and keep the truck or cut bait and trade it on a 3.0 Duramax. I've read a couple horror stories of engines letting go, dealer changing them out, and the replacement engine letting go shortly after installation, and I don't want to deal with it as I mainly use the truck to pull my boat on a 390 mile round trip several times a summer. It'd totally suck to have it let go on I-495 around DC during rush hour on the way home from the Bay. I'm just glad this one let go around 25 miles from home on the way to the Bay instead of waiting until we got 150 miles down the road.
Marky Dissod
... on the fence as to whether I want to take the chance and keep the truck or cut bait and trade it on a 3.0L Duramezzo.
I've read a couple horror stories of engines letting go, dealer changing them out, and the replacement engine letting go shortly after installation ...
How many of these horror stories involve any GM turbodiesel engines?
Johncunningham
I’ll chime in.
2023. Premier. 6.2. 22k miles. Driving yesterday afternoon 65mph ish. Screen goes black. Engine dead. Coasted to a stop. Dipstick looked fine. When we pulled the oil fill cap, an actual puff of Smoke came out. Had it towed to the nearest dealer. Got to google the transmission disconnect nonsense with the driver on the side of the road to get it there.
Of course we were 300 miles from home. They had a diagnosis in 5 minutes. Thrust bearing failure. Another word for Crankshaft bearing?
In any event I’m waiting to hear that the warranty claim is approved.
Also, worth repeating from upthread. It was completely free of drama. One moment cruising. Next moment dead. No shimmy. No shake. No crunch. No shudder. No loss of power. No smoke. No steam. No sound. Just dead…
Stbentoak
Since I have a diesel, I am somewhat of a disinterested 3rd party, but as a general question are the 5.3 engines exhibiting any all or some of the same issues lifters or thrust bearings, of the 6.2? If you were buying one today, and you had a choice, would you take a 5.3 over a 6.2? Or is there really no difference and they are all a crapshoot.......
TKOd Silverado
zero that i've read about but that doesn't mean it hasn't happened; i was referring to the 6.2L with that statement.
talked to dealership this morning and he was going on about their specific dealership having no issues like this from any they've sold but mine. when i called monday a week ago, the service manager told me when the mechanic came to get his next job, mine, that he asked what engine was in it and when told 6.2L he said he didn't need to look at it, go ahead and order an engine. he did, however, pull the oil filter and it was loaded with metal.
TKOd Silverado
same here, was cruising on an upgrade on the interstate and truck shut down. no notice, no light, no nothing, just shut down, drifted to side of road and called tow truck. tow truck driver told me i was his THIRD 2024 GM pickup he picked up that day, all of them just shutting down with no warning.
i'm working dealer to find me a diesel and give me a hell of a deal, but not looking too promising with them. i've found better deals online. i told him he made good money when he sold me that one 8 months ago and i didn't expect him to take a loss, but they need to take care of me on this one. he agreed, but that was simply the saleman coming out of him, i think.
It'd be nice to find out whether GM has resolved this lifter issue, or no. based on what i've read, the lifter valleys are oversized which causes the cam to whipe then the mains to go out, then you find yourself sitting along the road with an imploded engine.
Escalade2007
