DEF level sensor issue
972sparky
I have a 2022 and have used 2- 2 1/2 gallon jugs in just over 13,000 miles and is still showing 75% on Banks gauge. I estimate that is about a 1/2 gallon per thousand miles, no towing.
GARRELL
Ok. Thanks. Makes sense that mine at 5200 miles would only be down a little more than 2.5 gal. It did flash 7/8 ths on the guage a couple times and then back to FULL.
R
RK58
My sensor was reprogramed again and so far working as it should.
DLAv8r
N. Alabama
2023. Def full at last oil change at 7k miles. It hasn't budged off full in 1500 miles since and today I got a pop up message on app and in truck that my DEF was low and to fill up. I topped it off and the app and truck hasn't reset. It is still showing full on the DIC, but giving me the warning. Taking it in today to see if they can apply the TSB related to this to fix the glitch.
kerlyb
Was reprograming same as recent GM service bulletin 22-NA-150
  • #22-NA-150.pdf
Drusifer
What was the outcome of your dealer visit? My 2022 Tahoe’s DEF gauge shows 7/8ths full but got the DIC and app message last week that DEF is low. It was full 2,000 miles ago so I assume the gauge is accurate. Dropped it off at dealer yesterday and they just called letting me know it is ready. Said all it needed was an update.
Kenmotorist
I have the same exact issue. Gauge always showed full for circa 2k miles. Not towing. One day it showed 7/8 full then went back to full Took it in for oil change couple of weeks ago. They filled up the DEF tank. Told me no issues. Been driving about 200 miles since. Gauge showing 7/8 full. Very confusing. I would rather not carry a DEF bottle around. DEF should not be exposed to direct heat/sunlight. If l get low on DEF on a trip I’ll either do the nearest GM dealer or look for a truck stop with fresh DEF.
Jay P Wy
Navy
Natrona County WY
There is a TSB for this. From GM Trucks dot com ->
Attention diesel GM truck and SUV owners! General Motors has released a crucial service bulletin addressing specific issues related to the Malfunction Indicator Lamp (MIL) and Diesel Exhaust Fluid (DEF) level sensor. If you are driving any of the affected models listed below, check out if you have any symptoms that match those covered by this TSB.
Affected Vehicles:​
All models have a 3.0L Duramax (LM2) or 6.6L Duramax (L5P) Diesel Engine:
  • Cadillac Escalade Models (2021-2024)
  • Chevrolet Silverado 1500, 2500HD/3500HD, and Suburban (2020-2024)
  • Chevrolet Tahoe (2021-2024)
  • GMC Sierra 1500, 2500HD/3500HD (2020-2024)
  • GMC Yukon Models (2021-2024)
  • Chevrolet Silverado 1500 LTD (Specific VINs)
  • Chevrolet Silverado 1500 New (Specific VINs)
  • GMC Sierra 1500 Limited (Specific VINs)
  • GMC Sierra 1500 New (Specific VINs)
Symptoms:​
Owners of the affected vehicles may experience one or more of the following issues:
  • Illumination of the Malfunction Indicator Lamp (MIL)
  • Display of “Service Emission System” and/or “DEF Level Low” messages on the Driver Information Center (DIC)
  • Incorrect DEF level sensor readings
  • Erratic behavior of the DEF level sensor
  • DEF level sensor getting stuck
Cause:​
GM Engineers have determined that these issues may be attributed to a software anomaly within the vehicle’s system.
Repair Procedure:​
To address these issues, it is crucial for vehicle owners to take their vehicle to an authorized GM dealer. The dealer will perform the following steps:
  1. Update the K115 Reductant Control Module with the latest calibration.
  2. Ensure the DEF tank level reads at least 35% in GDS2. If not, add one gallon of Diesel Exhaust Fluid to the tank and perform a Reductant Fluid Tank Level Reset using GDS2.
  3. Fill the remainder of the Emission Reductant Fluid Tank with Diesel Exhaust Fluid.
  4. Clear any Diagnostic Trouble Codes (DTCs) after programming is complete.
  5. Please note that no parts are required for this repair, and the labor time is estimated at 0.9 hours.
TSB / Service Document Number:​
22-NA-150
Originally Issued in 2022 but reissued in October of 2023
Drusifer
Update on my issue. Got it back and gauge read 3/4ths. Drove a 1,200 mile trip the last couple of days. Stopped at QT 50 miles into the trip to fill up with DEF and it took 1.7 gallons, which is about a third of a tank. I would say the gauge is directionally accurate based on this. Didn’t receive any DIC or app alerts for low DEF during the trip.
R
RK58
I am sorry I don't know the reprogram they installed but the first time never cured the issue so I assume they did the service bulletin you mentioned. I just did a 1300 mile trip at highway speeds and it only went down 1 bar only took 2 quarts now back reading full. With 15,000 miles on it now it has been almost flawless.
BobHolthaus
After filling did it show full or still empty?
When towing (so using a lot of def) my wife's Denali will show 0 bars but still have more then 1/2 of a tank of def. When you fill it up it then shows a full tank of def. It has been to the dealer a couple times for this; all systems normal.
What is occurring is that the computer sees that it can't go more then 300 miles on the current amount of def so it sends the warning to the dash with a miles count down, when it does that it must think "well I warned them so I cannot show much def, I'm going to show you zero def" so the tank goes to zero even tho you have more then 1/2 a tank remaining.
When we tow for long distances (>1000 miles) this behavior occurs; doesn't happen on short trips (<250 miles).
Not sure if that is what is occurring for you; but this is supposedly a 'normal' behavior.
We have this exact issue. Did you find a fix?
Our DEF usage skyrockets when towing. We get these results when towing, every time: warning at ~900 miles left (could be less or more, our first warning pops us), then an hour later (and 80 miles later), we are at ~200 miles left. Gauge goes from 3/4 sometime to close to empty. Then it will take 2.5 gallons. It's completely erratic and not reliable. This only happens when towing, but it happens pretty much the same way every time. THIS IS NEW: This week the vehicle shows us a DEF range each time we start it (haven't towed in over a week, DEF tank filled last week) and its slowly counting UP from 200 miles of range, to 525 this morning. We laugh each day that we get more range, even though it's being driven daily. Our hope is that when it reaches some threshold, it won't give us our range on starting.
Edit: The article above from GM stating that the "gauge" is an algorithm makes sense to me. Which would explain why the system gets erratic only while towing, because its trying to "do the math" on what's left based upon strain on the engine, plus things like altitude, outside temperature, etc. It's like the computer gets drunk while towing and "does its best" to "do the math". In a $90,000 vehicle. Are actual float sensors really that expensive these days?!?!
Secondly, and most importantly: Will the vehicle go into limp mode while there is still DEF in the tank, because of the erratic “gauge”? Has anyone has this happen?
steiny93
Edit: The article above from GM stating that the "gauage" is an algorithm makes sense to me. Which would explain why the system gets erratic only while towing, because its trying to "do the math" on what's left based upon strain on the engine, plus things like altitude, outside temperature, etc. It's like the computer gets drunk while towing and "does its best" to "do the math". In a $90,000 vehicle. Are actual float sensors really that expensive these days?!?!
Secondly, and most importantly: Will the vehicle go into limp mode while there is still DEF in the tank, because of the erratic gauge? Has anyone has this happen?
Regarding the fix question:
Per multiple dealers and GM; nothing to fix as it is operating as intended.
:) yep, seriously, that's what I've been told.
Regarding the; does it go into limp mode question:
Yep, it will, it takes a bit in that it will go further then it says it will; but yah, you'll get to limp mode joy.
Mine doesn't do the counting up behavior, that's a new one. I haven't used the GMC for towing in quite a while due to this unacceptable behavior, maybe that is from a software update. Great when empty tho.
BobHolthaus
Good to know on limp mode. I guess when towing (which for us is interstate driving typically across state lines), I’ll just know that when we get out first “range left” indicator on the DIC, that we need to top off the def tank at the very next fuel stop, and not wait. Thanks for the reply.
Stbentoak
From what I understand the sensor is more like a "Sonar" and not a "Float" type level sensor. this it can be influenced easily high or low and is in exacting at best.
I dump a Wally world 2.5 in every 7500 miles roughly, and I've never been low and never been full....
BobHolthaus
Read this. Makes sense to me. Sorry, this is what I referencing above; this was on a different thread. Added above too.
BobHolthaus
Update: we had the TSB done at the dealer. We are on our second leg of a 600 mile (each way) vacation pulling a 5100 pound boat and trailer. We got one “X miles to empty on def” notice, but the gauge was accurate. With 2 of 8 bars gone, we took 1.7 gallons (which is accurate). We only got one warning for miles and then we didn’t get another one. In our opinion, the TSB really helped the situation. See above for our erratic garage and mileage warnings of the past.
But we still filled at the next truck stop! Although we did drive 4 hours at 80 mph and only use 1/4 of a def tank, which is really good. 70 degrees at the start of the trip. It’s 88° now; anxious to see if def usage goes up in warmer temps.
kerlyb
Which TSB was done....GM service bulletin 22-NA-150???
BobHolthaus
Yes, that is the one.
Second update: I didn’t get another mileage warning until the tank was at 2 bars. Then it was like a red alert, ha. I filled the def tank at the next stop and it took 4.7 gallons. Another mileage warning would have been nice, although the gauge was reading correctly.
JayceeP
Hi everyone - for those that are getting faulty low readings, have the sensors actually limited your speed? My DEF tank was full to the brim last week and I only drove a couple hundred km’s and noticed my dash displayed my range to empty on DEF (1,950 km’s….) am now getting the low def reading on my GMC app. I haven’t got that error in the truck yet so I’m assuming the sensor is messed up.
I have a road trip to go on this weekend so don’t want to assume the sensor wont shut me down despite having a full tank and don’t want to get stranded. DEF tank isn’t leaking either - truck is parked in the garage so I’d see the fluid.
Jay P Wy
Navy
Natrona County WY
There is a TSB for DEF level errors on GM trucks and SUVs. I think the TSB is 22-NA-150 (it's been updated to add new model years several times). It's a software update.
The level sensors in the DEF tank work the same way water & waste tank levels are in an RV (not very accurate). You can't have a float since the DEF is allowed to freeze in the tank.
johnsonwillie199
